世平集团推出ADI,Freescale安全、性能、成本兼备之智能电网解决方案
2012-08-20 20:34:16 本站原创世平集团为此推出 ADI,Freescale 智能电网解决方案:
一、ADI 智能电网方案
二、Freescale 可扩展Kinetis之ZigBee® 智慧能源无线解决方案
一、ADI 智能电网方案
ADI 作为全球混合信号处理技术领先者,是智能电网领域的主要电子系统解决方案供货商。ADI 在集成电能测量方面具有卓越的专业经验,采用 ADI 计量技术的电表已达3亿块; ADI 的高精度转换器和运算放大器保证了电压电流的精密测量;在全世界需要使用数模/模数转换器的电力设备中,大约有 50% 是采用 ADI 的转换器;ADI 高性能的信号处理能力保证了电网的实时可靠运行;ADI 针对电力应用提供系统级的混合信号设计方案,简化了设计复杂性并缩短了产品设计周期; ADI通过创新和增加信号处理集成度帮助用户的降低了系统成本。
方案框图:
主要芯片介绍:
1. ADI ADE7953 Single Phase Multifunction Metering
Features:
•Measures active, reactive, and apparent energy; sampled waveform; current and voltage RMS
•Provides a second current input for neutral current measurement
•Less than 0.1% error in active and reactive energy measurement over a dynamic range of 3000:1
•Less than 0.2% error in instantaneous IRMS and VRMS measurements over a dynamic range of 500:1
•Provides apparent energy measurement and instantaneous power readings
•1.5kHz bandwidth operation
•Flexible PGA gain stage (up to X22)
•Includes internal integrator for use with Rogowski coil
•SPI, I2C or UART communication
Specifications:
•Anti-Tamper Support: Missing Neutral
•Measurement Parameters : Irms, VA, VAR, Vrms, Watt, PF
•Current Sensor Interface: Current Shunt, Current Transformer, Rogowski Coil
•Package: 28-Lead LFCSP
2. ADI ADE7880 Polyphase Multifunction Metering
Features:
•Highly accurate; supports IEC 62053-21, IEC 62053-22, IEC 62053-23, EN 50470-1, EN 50470-3, ANSI C12.20, and IEEE1459 standards
•Supports IEC 61000-4-7 Class I and II accuracy specification
•Compatible with 3-phase, 3- or 4-wire (delta or wye), and other 3-phase services
•Supplies rms, active, reactive and apparent powers, power factor, THD+N and harmonic distortion of all harmonics within 2.8 KHz pass band on all phases
•Supplies rms and harmonic distortions of all harmonics within 2.8 KHz pass band on neutral current
•Supplies total (fundamental and harmonic) active and apparent energy and fundamental active/reactive energy on each phase and on the overall system
•Less than 0.1% error in active and fundamental reactive energy over a dynamic range of 1000 to 1 at TA = 25°C
•Less than 0.2% error in active and fundamental reactive energy over a dynamic range of 5000 to 1 at TA = 25°C
Specifications:
•Anti-Tamper Support: Current Fault
•Output Interface: HSDC,I2C,Pulsed,SPI
•Measurement Parameters : VA,VAR,Vrms,Watt, Irms
•Current Sensor Interface: Current Transformer,Rogowski Coil
•Package: 40-Lead LFCSP
3. ADE7169: Single-Phase Energy Measurement IC with 8052 MCU, RTC, and LCD Driver
Features:
•Wide supply voltage operation: 2.4 V to 3.7 V
•Internal bipolar switch between regulated and battery inputs
•Ultra low power operation with power saving modes (PSM)
•Low power battery mode
•Wake-up from I/O, temperature change, alarm, and UAR
•LCD driver operation
•Temperature measurement
•Proprietary ADCs and DSP provide anti-tampering detection, high accuracy active, reactive, and apparent energy measuremen
•Supports IEC 62053-21, IEC 62053-22, IEC 62053-23, EN 50470-3 Class A, Class B, and Class C, and ANSI C12-16
•Single-cycle 4MIPS 8052 core
•32.768 kHz external crystal with on-chip PLL
Specifications:
•Measurement Parameters : Irms,VA,VAR,Vrms,Watt
•Package: 64 -Lead LQFP (10x10mm)
4. ADI ADuCRF101 Precision Analog Microcontroller ARM Cortex M3 with ISM band Transceiver
Features:
•RF Transceiver
•Frequency bands, 862 MHz to 928 MHz and 431 MHz to 464 MHz
•Multiple Configurations supported
•Receiver sensitivity (BER), −107.5 dBm at 38.4 kbps, 2FSK
•Single and ended and differential PA
•Low External BOM
•Microcontroller
•ARM Cortex™-M3 32-bit processor
•Serial Wire download and debug
•External Watch crystal for wakeup timer
•16 MHz internal Oscillator with 8-way Programmable Divider
•Memory
•128k/64k Bytes Flash/EE Memory, 16k/8k Bytes SRAM
•20000 cycle Flash/EE endurance
•10 year Flash/EE retention
•In-circuit download via Serial Wire and UART
•On-Chip Peripherals
•UART, I2C and SPI Serial I/O
•28-Pin GPIO Port
•2 General Purpose Timers
•Wake-up Timer
•Watchdog Timer
•8-Channel PWM
•Power
•Supply Range: 2.2 V to 3.6 V
•Power Consumption;
•680 nA, in power down mode, non-retained state
•1.6 µA, in power down mode, MCU memory and transceiver memory retained
•190 µA / Mhz, Cortex in active mode
•12.8 mA transceiver in receive mode, Cortex in power down mode
•9 to 32 mA transceiver in transmit mode, Cortex in power down mode
•Analog I/O
•6-Channel, 14-bit or 12-bit ADC
•Single ended and differential inputs
•Programmable data rate up to 842kSPS
•On-Chip Voltage Reference and Temperature Sensor
•Packages and Temperature Range
•64 lead LFCSP (9mm x 9mm) package –40°C to 85°C
参考图片:
二、Freescale可扩展Kinetis之ZigBee® 智慧能源无线解决方案
Freescale发布了首个 ARM® Cortex™-M4 处理器在智能能源、智能电表和大楼控制等应用的无线解决方案,进一步扩充了Kinetis微控制器 (MCU) 产品组合。Freescale新一代 Kinetis 无线解决方案在 ZigBee® 平台上提供高性能及安全性,设计者可以根据他们的特定应用来优化解决方案。
Freescale设计Kinetis KW20无线微控制器系列的目的是应对未来 ZigBee 智能能源和互联网协议规范所带来的不断增长的处理和内存要求, Kinetis KW20无线微控制器整合了一个 ARM Cortex-M4 处理器与 MC1323/4 RF 收发器搭配形成一个强大的功能集,提供了一个可靠、安全且低功耗的 ZigBee 平台。工程师们可以选择KW20 MCU的单芯片解决方案,也可以选择将RF收发器和相对应的Kinetis MCU结合在一起,灵活地根据特定的应用需求定制。
Kinetis KW20无线微控制器提供高性能,满足智能能源应用的内存和安全需求,同时为设计师带来了最大程度的灵活性。Kinetis系列产品融入了ZigBee连接功能后,可以让用户的系统永不过时,同时获得更高的无线性能和额外的安全性。
Kinetis KW20 MCUs 和 MC1323X RF transceiver for 802.15.4 解决方案
Freescale的KW20无线MCU和MC13233/4 RF收发器通过低功耗和增加回路预算提供先进的RF性能。收发器是天线型分集收发器,可以增强RF可靠性,特别是在出现干扰的情况下。KW20 无线MCU和MC13233/4 RF收发器的设计可以降低传输和接收功率,其低功耗运行模式可以优化能源的利用。
KW20 无线MCU和MC13233/4 RF收发器具有独特的特性,提供双重个人局域网(PAN)支持,能够使用同一组件和两个ZigBee网络进行无线通信。此外,Freescale在组件中内含高端处理器中罕见的高级安全功能,满足客户对更先进的加密方法、密钥、安全内存及篡改侦查功能的需求。安全闪存保护代码和数据免遭非法入侵和修改,篡改侦查可以侦察到擦除事件,还可以异步擦除安全RAM并产生中断,使组件可以采取其他行动,包括系统重启。MMCAU(内存映像的加密加速单元)支持一套专门的操作来增强加密和解密操作的吞吐量以及消息摘要功能。在2008年,Freescale发布第一个32位ZigBee平台选择了IAR Systems的集成开发环境(IDE)直到现在,IAR System能够实现最有效的程序优化。
Kinetis KW20无线MCU规格
•ARM Cortex™-M4 core with DSP
•Up to 512 KB of flash and 64 KB of RAM
•Up to 64 KB of FlexMemory
•Secure flash & Tamper detect
•Cryptography acceleration unit
•High-performance IEEE 802.15.4-2011 transceiver
•Packet processor & Single ended
•Diversity
•Dual PAN support
•+10 dBm output power & -102 dBm sensitivity
•TX 15 mA @ 0 dBM(CPU sleep) & RX 15 mA
•128-bit random
•1.8 to 3.6-volt operating range
•Small footprint
•Compatible with Freescale Kinetis MCU family
•–40 ˚C to +105 ˚C operational temperature range
MC13233/4 RF收发器规格:
BeeKit 研发平台
无论开发者选择单芯片Kinetis KW20无线MCU解决方案,还是使用带有MC13233/4 RF收发器的多芯片解决方案,他们可以享用Kinetis MCU产品组合工具和软件。ZigBee协议软件已整合到Kinetis开发工具中,可以进一步加速开发时间。支持包括BeeKit无线连接工具箱,基于Eclipse™的CodeWarrior 集成开发环境(IDE)。Freescale MQX软件解决方案,和Tower System模块开发平台,可以快速提供原型产品。我们广阔的ARM生态系统还可以提供第三方开发支持,包括IAR的IDE。
