热度 28| |||
Stretch Type:Horizontal (Qualified) //拉伸类型:水平
Name or Expression for Stretch:strR3 //拉伸名称或表达式:
Stretch Directions(Default):right //拉伸方向(默认):
Reference Dimension(Default):0.81 //参考尺寸(默认):
Stretch Horizontally Repeated Figures¨ //拉伸水平重复的图形
Name or Expression for Stretch:strR2
Reference Dimension(Default):0.5
Name or Expression for Stretch:strR1
Reference Dimension(Default):0.9
Name or Expression for Stretch:L
Stretch Directions:right
Min Value:0.5 //最小值:
Stretch Horizontally Repeated Figuresþ //所有情况只有L需要拉伸水平重复
Stretch Type:Vertical (Qualified)
Name or Expression for Stretch:W
Stretch Directions:upAndDown
Reference Dimension(Default):0.6
Min Value:0.6 //最小值:
1.2 Conditional Inclusion (pcell>Conditional Inclusion)*左上角的pl5管子定义两个名称或表达式:Parallel、(W<0.9)
Number of Object in this group:10 //选中该组的对象数量:
Name or Expression:Parallel //名称或表达式:并联
Dependent Stretch: //依赖性拉伸:
Adjustment to Stretch: //调节拉伸:
Name or Expression:(W<0.9)
Dependent Stretch:
*右上角的pl5管子定义两个名称或表达式:Series、(W<0.9)
Name or Expression:Series
Dependent Stretch:
Dependent Stretch:
*左下角的pl5管子定义两个名称或表达式:Parallel、(W>=0.9)
Number of Object in this group:8
Dependent Stretch:
Name or Expression:(W>=0.9)
Dependent Stretch:
*右下角的pl5管子定义两个名称或表达式:Series、(W>=0.9)
Dependent Stretch:
Dependent Stretch:
1.3 Repetition (pcell>Repetition)*当条件为Parallel、W>=0.9时,管子左侧的cont进行Y方向上的重复。
Objects Repeated in:Y
Stepping Distance:0.9
Number of Repetition:(W/pcStepY)
Dependent Stretch:strR
Adjustment to Stretch:0
*当条件为Parallel、W>=0.9时,管子右侧的cont进行X和Y方向的重复。
Objects Repeated in:X and Y
X Stepping Distance:(1.05+L)
Y Stepping Distance:0.9
Number of X Repetition:M
Number of Y Repetition:(W/pcStepY)
Dependent X Stretch:strR
Dependent Y Stretch:
Adjustment to X Stretch:0.0
Adjustment to Y Stretch:
*当条件为Parallel、W>=0.9时,管子的poly进行X方向上的重复,默认调整拉伸。
Number of Repetition:M
Adjustment to Stretch:((fix(pcRepeatX)-1)*pcStepX)
*当条件为Series、W>=0.9时,管子的poly进行X方向上的重复,默认调整拉伸。
Stepping Distance:(0.5+L)
Dependent Stretch:strR2
*当条件为Series、W>=0.9时,管子左侧的cont进行Y方向上的重复。
*当条件为Series、W>=0.9时,管子右侧的cont进行Y方向上的重复。
*当条件为Series、W<0.9时,cont不存在Y方向上的重复。管子的poly进行X方向上的重复,默认调整拉伸。
Dependent Stretch:strR3
*当条件为Parallel、W<0.9时,cont不存在Y方向上的重复。管子的poly进行X方向上的重复,默认调整拉伸。
Stepping Distance:(1.3+L)
Dependent Stretch:strR1
*当条件为Parallel、W<0.9时,cont不存在Y方向上的重复,管子右侧的active+mt1+cont进行X方向上的重复。
Number of Object in this group:3
1.4Edit Parameters (pcell>Parameters)如上图设置L,M,W的最小值,不勾选Parallel和Series的False.
zcs841017: 博主你好,你的日志上点击图片,就能弹出新的窗口查看图片,为什么我写日志就不行呢?能否指导一下?我传的图片,都很不清晰,无奈只能再传图片附件,太麻烦了 ...
monika.er: 请问control line是如何高亮显示的呢?我stretch line不显示,所以需要选中时无法操作
