3. 创建页表
通过前面的两步,我们已经确定了processor type 和 machine type.
此时,一些特定寄存器的值如下所示:
r8 = machine info (struct machine_desc的基地址)
r9 = cpu id (通过cp15协处理器获得的cpu id)
r10 = procinfo (struct proc_info_list的基地址)
创建页表是通过函数 __create_page_tables 来实现的.
这里,我们使用的是arm的L1主页表,L1主页表也称为段页表(section page table)
L1 主页表将4 GB 的地址空间分成若干个1 MB的段(section),因此L1页表包含4096个页表项(section entry). 每个页表项是32 bits(4 bytes)
因而L1主页表占用 4096 *4 = 16k的内存空间.
对于ARM926,其L1 section entry的格式为:(可参考arm926EJS TRM):
31 20 19 12 11 10 9 8 5 4 3 2 1 0
| Base Address | SBZ | AP |0| Domain |1|C|B|1|0|
B - Write Buffer Bit
C - Cache Bit
| Data Cache |
| Cache Bit | Buffer Bit | Page attribute |
| 0 | 0 | not cached, not buffered |
| 0 | 1 | not cached, buffered |
| 1 | 0 | cached, writethrough |
| 1 | 1 | cached, writeback |
下面我们来分析 __create_page_tables 函数:
在 arch/arm/kernel/head.S 中:
- arm linux 从入口到start_kernel 代码分析 -
00206: .type __create_page_tables, %function
00207: __create_page_tables:
00208: pgtbl r4 @ page table address
00209:
00210:
00213: mov r0, r4
00214: mov r3, #0
00215: add r6, r0, #0x4000
00216: 1: str r3, [r0], #4
00217: str r3, [r0], #4
00218: str r3, [r0], #4
00219: str r3, [r0], #4
00220: teq r0, r6
00221: bne 1b
00222:
00223: ldr r7, [r10, #PROCINFO_MM_MMUFLAGS] @ mm_mmuflags
00224:
00225:
00231: mov r6, pc, lsr #20 @ start of kernel section
00232: orr r3, r7, r6, lsl #20 @ flags + kernel base
00233: str r3, [r4, r6, lsl #2] @ identity mapping
00234:
00235:
00239: add r0, r4, #(TEXTADDR & 0xff000000) >> 18 @ start of kernel
00240: str r3, [r0, #(TEXTADDR & 0x00f00000) >> 18]!
00241:
00242: ldr r6, =(_end - PAGE_OFFSET - 1) @ r6 = number of sections
00243: mov r6, r6, lsr #20 @ needed for kernel minus 1
00244:
00245: 1: add r3, r3, #1 << 20
00246: str r3, [r0, #4]!
00247: subs r6, r6, #1
00248: bgt 1b
00249:
00250:
00253: add r0, r4, #PAGE_OFFSET >> 18
00254: orr r6, r7, #PHYS_OFFSET
00255: str r6, [r0]
00314: mov pc, lr
00315: .ltorg
206, 207行: 函数声明
208行: 通过宏 pgtbl 将r4设置成页表的基地址(物理地址)
宏pgtbl 在 arch/arm/kernel/head.S 中:
00042: .macro pgtbl, rd
00043: ldr \rd, =(__virt_to_phys(KERNEL_RAM_ADDR - 0x4000))
00044: .endm
可以看到,页表是位于 KERNEL_RAM_ADDR 下面 16k 的位置
宏 __virt_to_phys 是在incude/asm-arm/memory.h 中:
00125: #ifndef __virt_to_phys
00126: #define __virt_to_phys(x) ((x) - PAGE_OFFSET + PHYS_OFFSET)
00127: #define __phys_to_virt(x) ((x) - PHYS_OFFSET + PAGE_OFFSET)
00128: #endif
下面从213行 - 221行, 是将这16k 的页表清0.
213行: r0 = r4, 将页表基地址存在r0中
214行: 将 r3 置成0
215行: r6 = 页表基地址 + 16k, 可以看到这是页表的尾地址
216 - 221 行: 循环,从 r0 到 r6 将这16k页表用0填充.
223行: 获得proc_info_list的__cpu_mm_mmu_flags的值,并存储到 r7中. (宏PROCINFO_MM_MMUFLAGS是在arch/arm/kernel/asm-offset.c中定义)
231行: 通过pc值的高12位(右移20位),得到kernel的section,并存储到r6中.因为当前是通过运行时地址得到的kernel的section,因而是物理地址.
232行: r3 = r7 | (r6 << 20); flags + kernel base,得到页表中需要设置的值.
233行: 设置页表: mem[r4 + r6 * 4] = r3
这里,因为页表的每一项是32 bits(4 bytes),所以要乘以4(<<2).
上面这三行,设置了kernel的第一个section(物理地址所在的page entry)的页表项
239, 240行: TEXTADDR是内核的起始虚拟地址(0xc0008000), 这两行是设置kernel起始虚拟地址的页表项(注意,这里设置的页表项和上面的231 - 233行设置的页表项是不同的 )
执行完后,r0指向kernel的第2个section的虚拟地址所在的页表项.
242行: 这一行计算kernel镜像的大小(bytes).
_end 是在vmlinux.lds.S中162行定义的,标记kernel的结束位置(虚拟地址):
00158 .bss : {
00159 __bss_start = .;
00160 *(.bss)
00161 *(COMMON)
00162 _end = .;
00163 }
kernel的size = _end - PAGE_OFFSET -1, 这里 减1的原因是因为 _end 是 location counter,它的地址是kernel镜像后面的一个byte的地址.
243行: 地址右移20位,计算出kernel有多少sections,并将结果存到r6中
245 - 248行: 这几行用来填充kernel所有section虚拟地址对应的页表项.
253行: 将r0设置为RAM第一兆虚拟地址的页表项地址(page entry)
254行: r7中存储的是mmu flags, 逻辑或上RAM的起始物理地址,得到RAM第一个MB页表项的值.
255行: 设置RAM的第一个MB虚拟地址的页表.
上面这三行是用来设置RAM中第一兆虚拟地址的页表. 之所以要设置这个页表项的原因是RAM的第一兆内存中可能存储着boot params.
这样,kernel所需要的基本的页表我们都设置完了, 如下图所示:
_,,_ _,,_
| KERNEL | | | |
+0x8000 ->+-----------+--------\ | | |
| L1 | | | | |
| Page Table| | | | |
+0x4000 ->+-----------+ | | | |
| Boot | | | | |
| Params | | | | |
PAGE_OFFSET(3G) ->+-----------+---\ | | | |
| | | | | KERNEL |
| 1MB | | | | |
PHYS_OFFSET+0x8000 ->+- - - - - -+--------+------->'-----------+<- +0x8000
| | | | L1 |
| | | | Page Table|
| | | +-----------+<- +0x4000
| | | | Boot |
| | | | Params |
| | \------------>+-----------+<- PHYS_OFFSET
| | | _,,_ |
0 --+-----------+
VIRT Address PHYS Address
本文来自: (www.91linux.com) 详细出处参考:http://www.91linux.com/html/article/qianrushiyingyong/arm_linux/2010/0909/20474.html
