yiffer的个人空间 https://blog.eetop.cn/edesign [收藏] [复制] [分享] [RSS]
Request_irq和setup_irq的区别
已有 1346 次阅读| 2010-7-21 21:59 |个人分类:Linux移植
Linux 内核提供了两个注册中断处理函数的接口:setup_irqrequest_irq。这两个函数都定义在kernel/irq/manage.c里。
 * Internal function to register an irqaction - typically used to
 * allocate special interrupts that are part of the architecture.
int setup_irq(unsigned int irq, struct irqaction *new);
 *    request_irq - allocate an interrupt line
*    This call allocates interrupt resources and enables the
 *    interrupt line and IRQ handling.
int request_irq(unsigned int irq,
              irqreturn_t (*handler)(int, void *, struct pt_regs *),
              unsigned long irqflags, const char *devname, void *dev_id)
这两个函数有什么样的区别呢?
先看看setup_irq
Setup_irq通常用在系统时钟(GP Timer)驱动里,注册系统时钟驱动的中断处理函数。
下面举个列子, s3c2410 timer驱动:
/* arch/arm/mach-s3c2410/time.c */
static struct irqaction s3c2410_timer_irq = {
       .name          = "S3C2410 Timer Tick",
       .flags            = IRQF_DISABLED | IRQF_TIMER,
       .handler       = s3c2410_timer_interrupt,
static void __init s3c2410_timer_init (void)
       s3c2410_timer_setup();
       setup_irq(IRQ_TIMER4, &s3c2410_timer_irq);
struct sys_timer s3c24xx_timer = {
       .init        = s3c2410_timer_init,
       .offset           = s3c2410_gettimeoffset,
       .resume        = s3c2410_timer_setup
可以看到,setup_irq的使用流程很简单。首先定义s3c2410 timer驱动的irqaction结构体,该结构体用于描述timer中断的基本属性包括中断名、类别以及该中断handler等。然后通过setup_irq函数将timerirqaction注册进内核。其中,IRQ_TIMER4s3c2410 timer的中断号。
再看看request_irq
request_irq源码如下:
/* kernel/irq/manage.c */
       struct irqaction *action;
       int retval;
#ifdef CONFIG_LOCKDEP
        * Lockdep wants atomic interrupt handlers:
       irqflags |= SA_INTERRUPT;
#endif
        * Sanity-check: shared interrupts must pass in a real dev-ID,
        * otherwise we'll have trouble later trying to figure out
        * which interrupt is which (messes up the interrupt freeing
        * logic etc).
       if ((irqflags & IRQF_SHARED) && !dev_id)   /* 使用共享中断但没有提供非NULLdev_id则返回错误 */
              return -EINVAL;
       if (irq >= NR_IRQS)            /* 中断号超出最大值 */
              return -EINVAL;
       if (irq_desc[irq].status & IRQ_NOREQUEST) /* 该中断号已被使用并且未共享 */
              return -EINVAL;
       if (!handler)
              return -EINVAL;
       action = kmalloc(sizeof(struct irqaction), GFP_ATOMIC);     /* 动态创建一个irqaction */
       if (!action)
              return -ENOMEM;
/* 下面几行是根据request_irq 传进来的参数对irqaction结构体赋值 */
       action->handler = handler;
       action->flags = irqflags;
       cpus_clear(action->mask);
       action->name = devname;
       action->next = NULL;
       action->dev_id = dev_id;
       select_smp_affinity(irq);
       retval = setup_irq(irq, action);      /* 调用setup_irq注册该中断的irqaction结构体 */
       if (retval)
              kfree(action);
       return retval;
由上可以看出,request_irq的大致流程为先对申请的中断线进行安全检测,然后根据request_irq传进来的参数,动态创建该中断对应的irqaction结构体,最后通过setup_irq函数将该irqaction注册进内核适当的位置。
这两个函数的使用流程搞清楚了,那么两者之间的联系也就清楚了:
1) Request_irq的注册过程包含setup_irq,最终是调用setup_irq
2) Request_irqsetup_irq多一套错误检测机制,即kmalloc前面3if语句。
Setup_irq通常是直接注册irqaction,并没针对相应中断线进行错误检测,如该irq 线是否已经被占用等。因此setup_irq通常只用在特定的中断线上,如System timer。除系统时钟驱动外,大部份驱动还是通过request_irq注册中断。
这里有个小问题:
既然Request_irq实际上就是包含了setup_irq的注册过程,那系统时钟驱动(GP Timer Driver)中断可以用request_irq来注册吗?
做个小试验, s3c2410 timer驱动的setup_irq那行去掉,改为用request_irq注册。
修改后代码如下:
       //setup_irq(IRQ_TIMER4, &s3c2410_timer_irq);
       request_irq(IRQ_TIMER4, s3c2410_timer_interrupt,
        IRQF_DISABLED | IRQF_TIMER, "S3C2410 Timer Tick", NULL);
编译运行。
结果:内核挂掉
为什么呢?很明显,系统时钟驱动中断不能用request_irq注册,大致搜了一下源码也发现,看到其他平台相关的时钟驱动中断部分都是用的setup_irq注册的。
我们来分析一下原因。
看看request_irqsetup_irq 还有哪些细节不一样?
仔细观察后注意到request_irq内有这么一行代码:
作用为动态创建一个irqaction
Kmalloc实际上也是使用的slab机制进行分配的。源码如下:
/* include/linux/slab.h */
static inline void *kmalloc(size_t size, gfp_t flags)
       if (__builtin_constant_p(size)) {
              int i = 0;
#define CACHE(x) \
              if (size <= x) \
                     goto found; \
              else \
                     i++;
#include "kmalloc_sizes.h"
#undef CACHE
                     extern void __you_cannot_kmalloc_that_much(void);
                     __you_cannot_kmalloc_that_much();
found:
              return kmem_cache_alloc((flags & GFP_DMA) ?
                     malloc_sizes[i].cs_dmacachep :
                     malloc_sizes[i].cs_cachep, flags);
       return __kmalloc(size, flags);
使用slab机制分配内存必须先对slab进行初始化,包括mem_initkmem_cache_init
看看kernel的初始化流程:
/* init/main.c */
asmlinkage void __init start_kernel(void)
       time_init();
       vfs_caches_init_early();
       cpuset_init_early();
       mem_init();  ß------ initializes the memory data structures
       kmem_cache_init(); ß---- set up the general caches
Time_init函数在mem_initkmem_cache_init之前被调用,而time_init会调用体系结构相关部分系统时钟驱动的初始化函数。拿s3c2410的例子来说,time_init最终会调用s3c2410_timer_init函数,进行s3c2410时钟驱动的初始化和注册中断处理函数。
具体过程如下:
time_init函数定义在arch/arm/kernel/time.c:
void __init time_init(void)
#ifndef CONFIG_GENERIC_TIME
       if (system_timer->offset == NULL)
              system_timer->offset = dummy_gettimeoffset;
#endif
       system_timer->init();  ß-这行实际执行的就是s3c2410_timer_init
#ifdef CONFIG_NO_IDLE_HZ
       if (system_timer->dyn_tick)
              system_timer->dyn_tick->lock = SPIN_LOCK_UNLOCKED;
#endif
system_timersetup_arch(arch/arm/kernel/setup.c)内通过map_desc机制被初始化为s3c24xx_timer. 如上面s3c2410时钟驱动代码所示,s3c24xx_timerinit成员即指向s3c2410_timer_init函数。
现在我们搞清楚了,我们大概的估计是系统时钟驱动(GP Timer Driver)的中断处理函数不能用request_irq注册是因为request_irq内会调用kmalloc动态分配内存创建timerirqaction结构体。而kmalloc也是使用的slab内存分配机制,使用kmalloc前必须先对kernelslab以及mem data structure进行初始化。而这部分初始化工作是在系统时钟驱动初始化之后才进行的,所以造成kmalloc失败,从而造成系统时钟驱动的中断未注册成功,进而内核挂掉。
本文来源:http://www.cublog.cn/u2/60011/showart_1086511.html
  • 3
  • 20
  • 69
  • 3705
GMT+8, 2024-4-20 20:37 , Processed in 0.020665 second(s), 7 queries , Gzip On, Redis On.
