If you want to view the power waveforms in an ASCII format, use the PrimeTime PX tool to generate a .out file which is of the ASCII format using the following command:
pt_shell> set_power_analysis_options -waveform_format out -waveform_output file_name
-waveform_format fsdb|out|none
