【转载】SMIC-Synopsys Reference Flow 5.0
上一篇 / 下一篇  2017-06-20 08:14:17 / 个人分类:reference flow
SMIC-Synopsys Reference Flow 5.0, a chip-level flat design flow from RTL to verified GDSII, once again delivers a low power design. Reference Flow 5.0 uses SMIC’s advanced 40-nanometer Low Leakage process (40LL) with the Synopsys Galaxy implementation platform, and all the scripts are compatible with the Synopsys Lynx Design System. Anchored by Synopsys' Design Compiler, IC Compiler, PrimeTime Suite, StarRC, Formality, VCS , DFT Compiler MAX, TetraMax, Hercules, PrimeRail, and HSIMplus, the Galaxy Design Platform. reduces design cycle, decreases integration costs and helps minimize risks inherent in advanced, complex IC design.
This proven reference flow was validated using the ARM SMIC 40nm multiple channel standard cell library, Power Management Kit, memory compiler, SMIC in-house PLL and IO to illustrate a power-gating design. In addition, the reference flow leverages Unified Power Format (UPF), an IEEE standard for defining low power design intended to improve the way complex System-on-Chip (SoC) designs are implemented and verified.
SMIC and Synopsys’ collaboration has enabled IC designers to accelerate their designs into manufacturing, with a flexible, lower-risk environment and faster time-to-market with SMIC’s 40nm process technology.
SMIC-Synopsys Reference Flow 5.0 highlights:
ARM SMIC 40LL library R2G design flow
Advanced SMIC 40nm design rule support
All scripts are compatible with the Synopsys Lynx Design System
Chip-level Low Power UPF design
Multi-VT libraries for leakage reduction optimization
Multi-channel libraries for leakage reduction optimization
Gate Array ECO flow
SMIC-Synopsys Reference Flow 5.0 Architecture
The SMIC-Synopsys Reference Flow package includes:
Design flow scripts
Technology and library preparation scripts
Sample test cases, one block level and one low power chip-level design
Flow setup and execution manual
Most importantly, we have trained experts ready to support and offer you professional advice to bring your design to high-quality sign-off GDSII.
If you would like to know more about the SMIC-Synopsys Reference Flow 5.0, please contact your SMIC account manager, login toSMIC Now or send us a message.
TAG: flow 40nm
评分:0
我来说两句
显示全部
日历
« 2018-01-16
 123456
78910111213
14151617181920
21222324252627
28293031
数据统计
  • 访问量: 7321
  • 日志数: 35
  • 建立时间: 2017-05-19
  • 更新时间: 2017-07-28
RSS订阅
Open Toolbar
