热度 1| ||
function [snrdB,ptotdB,psigdB,pnoisedB] = calcSNR_lu(vout,Fin,Fs,N,R)
% vout: input size is data(1,N)
% Fin : signal 's frequency in analog domain
% Fs : sampling rate for current stage
% N: samples number for current stage
% R: total oversampling factor for current stage after previous stage's
% decimation
% snrdB: SNR in dB
% ptotdB: Bit-stream power spectral density (vector)
% psigdB: Extracted signal power spectral density (vector)
% pnoisedB: Noise power spectral density (vector)
N=floor(N);
%w=hann(N)'; % windowing vector
w=blackman(N,'periodic')';
f=Fin/Fs; % Normalized signal frequency,Fin=Fs*nper/N;=> f=nper/N % Normalized signal frequency,Fin=Fs*nper/N;=> f=nper/N
fB=N/2/R; % Base-band frequency bins,always keep same,bw=Fs/2/R;=>fB=N/2/R,R is osr in current stage
fB=ceil(fB);
signal=(N/sum(w))*sinusx(vout(1:N).*w,f,N); % Extracts sinusoidal signal
noise=vout(1:N)-signal; % Extracts noise components
stot=((abs(fft((vout(1:N).*w)'))).^2); % Bit-stream PSD
ssignal=(abs(fft((signal(1:N).*w)'))).^2; % Signal PSD
snoise=(abs(fft((noise(1:N).*w)'))).^2; % Noise PSD
pwsignal=sum(ssignal(1:fB)); % Signal power
pwnoise=sum(snoise(5:fB)); % Noise power,skip DC
snr=pwsignal/pwnoise;
snrdB=dbp(snr);
norm=sum(stot)/sum(vout(1:N).^2)*N; % PSD normalization
if nargout > 1
ptot=stot/norm;
ptotdB=dbp(ptot);
end
if nargout > 2
psig=ssignal/norm;
psigdB=dbp(psig);
end
if nargout > 3
pnoise=snoise/norm;
pnoisedB=dbp(pnoise);
end
function SNR = snr_qian_lvkun(s_y,frq,sfrq,bw)
% s_y: data
% frq: Input frequency
% sfrq: sampling frequency
% bw: bandwitdh of the signal
% frq/fres= frq/sfrq*Ns=int number,=>Ns=int_number*sfrq/frq
format long
Ns=20*sfrq/frq;
s_y=s_y(1:Ns);
%Ns <=length(s_y)
w = hanning(Ns, 'periodic');
z = 1;
[a, fre] = pwelch(s_y, w, [], Ns, sfrq);
fres = sfrq / Ns;
bx = round(Ns * bw/sfrq + 1);
bbpwr = fres * sum(a(z+2:bx));
sigbin = 1+ round(frq/fres);
sigbinmin = max([(sigbin-z) 1]);
sigbinmax = sigbin+z;
sigpwr = fres * sum(a(sigbinmin:sigbinmax));
SNR = 20*log10(sqrt(sigpwr/(bbpwr-sigpwr)));
figure
semilogx(fre, pow2db(a), 'r');
xlabel('Frequency(Hz)', 'FontWeight', 'Bold', 'FontSize',10);
ylabel('PSD(dB/Hz)', 'FontWeight', 'Bold', 'FontSize',10);
title('CIFB3L7B output PSD');
txt = ['\leftarrow SNR=', num2str(SNR)];
text(20e3, pow2db(max(a))-10, txt);
grid on;
hold on;
plot([fres 20e3], [pow2db(max(a)) pow2db(max(a))], 'b--', 'LineWidth', 1);
plot([20e3 20e3], [pow2db(min(a)) pow2db(max(a))], 'b--', 'LineWidth', 1);
plot([20e3 0.5*sfrq], [pow2db(min(a)) pow2db(min(a))], 'b--', 'LineWidth', 1);
