# # The example of the previous lesson revisited - using dicts. # proc addname {dbVar first last} { upvar 1 $dbVar db # Create a new ID (stored in the name array too for easy access) dict incr db ID set id [dict get $db ID] # Create the new record dict set db $id first $first dict set db $id last $last } proc report {db} { # Loop over the last names: make a map from last name to ID dict for {id name} $db { # Create a temporary dictionary mapping from # last name to ID, for reverse lookup puts "id:$id-name:$name-"; if {$id eq "ID"} { continue } set last [dict get $name last] dict set tmp $last $id } # # Now we can easily print the names in the order we want! # foreach last [lsort [dict keys $tmp]] { set id [dict get $tmp $last] puts " [dict get $db $id first] $last" } } # # Initialise the array and add a few names # dict set fictional_name ID 0 dict set historical_name ID 0 addname fictional_name Mary Poppins addname fictional_name Uriah Heep addname fictional_name Frodo Baggins addname historical_name Rene Descartes addname historical_name Richard Lionheart addname historical_name Leonardo "da Vinci" addname historical_name Charles Baudelaire addname historical_name Julius Caesar
the key->value is ID->3,1->dictionary(first-> last->)
