代理GV7601 GV7600 GV8500 13714730175
一级代理 GV7600 GV7600-IBE3 13714730175
HD-SDI高清接口芯片GV7600、GV7601 13714730175
The GV7600 is a serial digital video transmitter for standard and high definition component video.
With integrated cable driving technology, the GV7600 is capable of transmitting digital video at 270Mb/s, 1.485Gb/s and 2.97Gb/s over 75Ω coaxial cable. The device provides a complete transmit solution for the transmission of both interlaced and progressive component digital video, up to 1920 x 1080, in coaxial cable-based video systems.
Features
Supports HD formats:
720p24, 25, 30, 50 & 60
1080i50 & 60
1080p24, 25, 30, 50 & 60
Supports 525i & 625i SD D1 format
16/20-bit BT.1120 YCbCr 4:2:2 at 74.25 MHz or YCbCr/RGB 4:4:4 input at 148.5 MHz
8/10-bit BT.656 YCbCr 4:2:2 input at 27 MHz
Integrated cable driver for long distance transmission over 75Ω coaxial cables at 270 Mb/s, 1.485 Gb/s & 2.97 Gb/s
Support up to 8 channels of S/PDIF or I2S serial digital audio input at 48 kHz sampling
IEC 13818-1 transport interface (TSIF) for transmission of compressed A/V transport stream
Auxiliary data insertion via SPI interface
11mm x 11mm 100-BGA
Power: 400mW typical
Wide temp. range: -20°C to +85°C
Applications
Industrial & surveillance cameras
Video servers, mixers & switchers
Camcorders
Video compression CODECs
Targeted Markets:
Surveillance & HD-CCTV
Machine Vision
Digital Signage
Large Venue Displays
Video Conferencing
Medical Imaging
Industrial A/V
Passenger Infotainment
Order Codes
Part No
Package
GV7600-IBE3
Tray (168 pcs)
该gv7600是串行数字视频传输的标准和高清晰度视频。
用综合电缆驱动技术,该gv7600能够在270Mb / s的数字视频传输,1.485gb/s和2.97gb/s超过75Ω同轴电缆。该设备提供了一个完整的传输解决方案的隔行扫描和逐行分量数字视频的传输,可达1920×1080,同轴电缆为基础的视频系统。
特征
支持高清格式:
720p24,25,30,50和60
1080i50 & 60
25,30,1080p24,50和60
支持525i和625i SD D1格式
16 / 20位bt.1120 YCbCr 4:2:2 YCbCr或者RGB 74.25兆赫或4:4:4的输入在148.5兆赫
8 / 10位的BT.656 YCbCr 4:2:2输入在27兆赫
综合电缆驱动的长距离传输超过75Ω同轴电缆在270 Mb / s,1.485 GB / s和2.97 GB /
支持多达8个S/PDIF或I2S串行数字音频输入48千赫采样
IEC 13818-1传输接口(TSIF)用于传输压缩的A / V传输流
插入辅助数据通过SPI接口
100-bga 11mm×11mm
功率:400MW典型
宽温度。范围:20°C + 85°C
应用
工业监控摄像机
视频服务器,混频器和开关
摄像机
视频压缩编解码器
目标市场:
监控hd-cctv
机器视觉
数字标牌
大型场馆展示
视频会议
医学影像
工业/ V
旅客信息
命令码
部分没有
包
gv7600-ibe3
托盘(168件)
双语对照
