代理GV8500 GV7600 GV7601 13714730175
一级代理GV8500 GV8500-CNE3 13714730175
The GV8500 is a high-speed BiCMOS integrated circuit designed to drive one or two 75 ohms coaxial cables. The GV8500 can drive data rates up to 2.970Gb/s, and provides two selectable slew rates in order to achieve compliance to HDcctv 1.0, ST 292 at 1.485Gb/s, ST 424 at 2.970Gb/s, and ST 259 at 270Mb/s.
Features
HDcctv 1.0, HD-SDI (ST 292), 3G-SDI (ST 424) and SD-SDI (ST 259) compliant
Dual coaxial cable driving outputs with selectable slew rate
50 ohms differential PECL input
Pb-free and RoHS compliant
Single 3.3V power supply operation
Operating temperature range: 0°C to 70°C
Small footprint (4mm x 4mm)
Applications
Security and surveillance cameras
Industrial and professional cameras
Digital video recorders (DVR)
Video mixers and switchers
Camcorders
Distribution amplifiers
Repeaters
Order Codes
Part No.
Package
GV8500-CNE3
16-pin QFN
该gv8500是一种高速BiCMOS集成电路设计用于驱动一个或两个75欧姆同轴电缆。该gv8500可以驱动数据速率高达2.970gb/s,并提供了两种可选择的转换率达到符合HDcctv 1,ST 292 1.485gb/s,ST 424 2.970gb/s,ST 259在270Mb / s
特征
HDcctv 1,HD-SDI(292街),3G-SDI(ST 424)和SD-SDI(ST 259)兼容的
双同轴电缆驱动输出可选择的转换率
50欧姆差分PECL输入
无铅,符合RoHS
单3.3V电源操作
工作温度范围:0到70°°C C
小的足迹(4mm×4mm)
应用
安全和监控摄像机
工业和专业相机
数字视频录像机(DVR)
视频混频器和开关
摄像机
分布放大器
中继器
命令码
零件号
包
gv8500-cne3
16引脚QFN
