两互相垂直的,频率成一定整数比例关系的简谐振动合成,合振动为有一定规则的稳定的闭合曲线,称李萨如曲线。运行程序,令a=pi/3,k=3可得李萨如曲线
function varargout = zhuwx(varargin)
% ZHUWX M-file for zhuwx.fig
% ZHUWX, by itself, creates a new ZHUWX or raises the existing
% singleton*.
% H = ZHUWX returns the handle to a new ZHUWX or the handle to
% the existing singleton*.
% ZHUWX('CALLBACK',hObject,eventData,handles,...) calls the local
% function named CALLBACK in ZHUWX.M with the given input arguments.
% ZHUWX('Property','Value',...) creates a new ZHUWX or raises the
% existing singleton*. Starting from the left, property value pairs are
% applied to the GUI before zhuwx_OpeningFunction gets called. An
% unrecognized property name or invalid value makes property application
% stop. All inputs are passed to zhuwx_OpeningFcn via varargin.
% *See GUI Options on GUIDE's Tools menu. Choose "GUI allows only one
% instance to run (singleton)".
% See also: GUIDE, GUIDATA, GUIHANDLES
% Edit the above text to modify the response to help zhuwx
% Last Modified by GUIDE v2.5 10-Jan-2005 18:31:53
% Begin initialization code - DO NOT EDIT
gui_Singleton = 1;
gui_State = struct('gui_Name', mfilename, ...
'gui_Singleton', gui_Singleton, ...
'gui_OpeningFcn', @zhuwx_OpeningFcn, ...
'gui_OutputFcn', @zhuwx_OutputFcn, ...
'gui_LayoutFcn', [] , ...
'gui_Callback', []);
if nargin & isstr(varargin{1})
gui_State.gui_Callback = str2func(varargin{1});
end
if nargout
[varargout{1:nargout}] = gui_mainfcn(gui_State, varargin{:});
else
end
% End initialization code - DO NOT EDIT
% --- Executes just before zhuwx is made visible.
function zhuwx_OpeningFcn(hObject, eventdata, handles, varargin)
% This function has no output args, see OutputFcn.
% hObject handle to figure
% eventdata reserved - to be defined in a future version of MATLAB
% handles structure with handles and user data (see GUIDATA)
% varargin command line arguments to zhuwx (see VARARGIN)
% Choose default command line output for zhuwx
handles.output = hObject;
% Update handles structure
guidata(hObject, handles);
% UIWAIT makes zhuwx wait for user response (see UIRESUME)
% uiwait(handles.figure1);
% --- Outputs from this function are returned to the command line.
function varargout = zhuwx_OutputFcn(hObject, eventdata, handles)
% varargout cell array for returning output args (see VARARGOUT);
% Get default command line output from handles structure
varargout{1} = handles.output;
% --- Executes during object creation, after setting all properties.
function popupmenu1_CreateFcn(hObject, eventdata, handles)
% hObject handle to popupmenu1 (see GCBO)
% handles empty - handles not created until after all CreateFcns called
% Hint: popupmenu controls usually have a white background on Windows.
% See ISPC and COMPUTER.
if ispc
set(hObject,'BackgroundColor','white');
else
set(hObject,'BackgroundColor',get(0,'defaultUicontrolBackgroundColor'));
end
% --- Executes on selection change in popupmenu1.
function popupmenu1_Callback(hObject, eventdata, handles)
% Hints: contents = get(hObject,'String') returns popupmenu1 contents as cell array
% contents{get(hObject,'Value')} returns selected item from popupmenu1
function popupmenu2_CreateFcn(hObject, eventdata, handles)
% hObject handle to popupmenu2 (see GCBO)
if ispc
else
end
% --- Executes on selection change in popupmenu2.
function popupmenu2_Callback(hObject, eventdata, handles)
% Hints: contents = get(hObject,'String') returns popupmenu2 contents as cell array
% contents{get(hObject,'Value')} returns selected item from popupmenu2
% --- Executes on button press in pushbutton1.
function pushbutton1_Callback(hObject, eventdata, handles)
% hObject handle to pushbutton1 (see GCBO)
ax=get(handles.popupmenu1,'Value');
switch ax
case 1
a=1/3;
case 2
a=1/2;
case 3
a=2/3;
case 4
