请问大家遇到过 下面的时钟问题没有?
Place:1138 - Automatic clock placement failed. Please attempt to analyze the global clocking required for this
design and either lock the clock placement or area locate the logic driven by the clocks so that the clocks may be
placed in such a way that all logic driven by them may be routed. The main restriction on clock placement is that
only one clock output signal for any competing Global / Side pair of clocks may enter any region. For further
information see the "Quadrant Clock Routing" section in the Spartan3a Family Datasheet.
The competing Global / Side clock buffers for this device are as follows:
BUFGMUX_X2Y1 : BUFGMUX_X0Y2
BUFGMUX_X2Y0 : BUFGMUX_X0Y3
BUFGMUX_X1Y1 : BUFGMUX_X0Y4
BUFGMUX_X1Y0 : BUFGMUX_X0Y5
BUFGMUX_X2Y11 : BUFGMUX_X0Y6
BUFGMUX_X2Y10 : BUFGMUX_X0Y7
BUFGMUX_X1Y11 : BUFGMUX_X0Y8
BUFGMUX_X1Y10 : BUFGMUX_X0Y9
BUFGMUX_X2Y1 : BUFGMUX_X3Y2
BUFGMUX_X2Y0 : BUFGMUX_X3Y3
BUFGMUX_X1Y1 : BUFGMUX_X3Y4
BUFGMUX_X1Y0 : BUFGMUX_X3Y5
BUFGMUX_X2Y11 : BUFGMUX_X3Y6
BUFGMUX_X2Y10 : BUFGMUX_X3Y7
BUFGMUX_X1Y11 : BUFGMUX_X3Y8
BUFGMUX_X1Y10 : BUFGMUX_X3Y9
Phase 5.30 Global Clock Region Assignment (Checksum:6a77b3ee) REAL time: 25 secs
Total REAL time to Placer completion: 25 secs
Total CPU time to Placer completion: 25 secs
Partition Implementation Status
No Partitions were found in this design.
Generating "PAR" statistics.
Generating Clock Report
| Clock Net | Resource |Locked|Fanout|Net Skew(ns)|Max Delay(ns)|
| Clk100MOut10* | BUFGMUX_X2Y0| No | 394 | 0.000 | |
| CLKOUT_IBUF* | BUFGMUX_X0Y2| No | 679 | 0.000 | |
| ADCLK1_OBUF* | BUFGMUX_X2Y1| No | 300 | 0.000 | |
| CLK4X* | BUFGMUX_X2Y11| No | 120 | 0.000 | |
| CLKLow_OUT* | BUFGMUX_X1Y0| No | 86 | 0.000 | |
|DivClkVhdl_u1/Cal_1K | | | | | |
| hz0* | BUFGMUX_X3Y4| No | 17 | 0.000 | |
| usb_mcu_f0_IBUF* | BUFGMUX_X0Y9| No | 16 | 0.000 | |
|DivClkVhdl_u1/clk200 | | | | | |
| * | BUFGMUX_X1Y1| No | 6 | 0.000 | |
| sample_clk* | BUFGMUX_X3Y2| No | 11 | 0.000 | |
|serial_eeprom/clkdv_ | | | | | |
| out_ff* | BUFGMUX_X3Y5| No | 32 | 0.000 | |
| Clk20M* | BUFGMUX_X1Y10| No | 19 | 0.000 | |
|usbport/Capture_Star | | | | | |
| t* | Local| | 215 | 0.000 | |
| pwm_u/COUNT<2>* | Local| | 7 | 0.494 | |
|trig_in_u1/trig_whol | | | | | |
| e* | Local| | 2 | 2.094 | |
|la_u/s16to1_inst/dat | | | | | |
| aout3* | Local| | 3 | 0.320 | |
* Some of the Clock networks are NOT completely routed
* Net Skew is the difference between the minimum and maximum routing
only delays for the net. Note this is different from Clock Skew which
is reported in TRCE timing report. Clock Skew is the difference between
the minimum and maximum path delays which includes logic delays.
Timing Score: 234895 (Setup: 234843, Hold: 52, Component Switching Limit: 0)
我加了bufg后,逻辑跑起来就不太对了,请问大家有好的方法吗?
