From ieee 1800
bind_directive ::=
bind bind_target_scope [ : bind_target_instance_list] bind_instantiation ;
| bind bind_target_instance bind_instantiation ;
bind_target_scope ::= module_identifier | interface_identifier
bind_target_instance ::= hierarchical_identifier constant_bit_select
bind_target_instance_list ::= bind_target_instance { , bind_target_instance }
bind_instantiation ::= program_instantiation | module_instantiation | interface_instantiation | checker_instantiation
The bind directive can be specified in any of the following:
— A module
— An interface
— A compilation-unit scope
There are two forms of bind syntax. In the first form, bind_target_scope specifies a target scope into which
the bind_instantiation should be inserted. A bind target scope shall be a module or an interface. A bind
target instance shall be an instance of a module or an interface. In the absence of a bind_target_instance_list,
the bind_instantiation is inserted into all instances of the specified target scope, designwide. If a
bind_target_instance_list is present, the bind_instantiation is only inserted into the specified instances of
the target scope. The bind_instantiation is effectively a complete module, interface, program, or checker
instantiation statement.
The second form. of bind syntax can be used to specify a single instance into which the bind_instantiation
should be inserted. If the second form. of bind syntax is used and the bind_target_instance identifier resolves
to both an instance name and a module name, binding shall only occur to the specified instance.
