转:https://en.wikipedia.org/wiki/Advanced_Microcontroller_Bus_Architecture
The ARM Advanced Microcontroller Bus Architecture (AMBA) is an open-standard, on-chip interconnect specification for the connection and management of functional blocks in system-on-a-chip (SoC) designs. It facilitates development of multi-processor designs with large numbers of controllers and peripherals. Since its inception, the scope of AMBA has, despite its name, gone far beyond micro controller devices. Today, AMBA is widely used on a range of ASIC and SoC parts including applications processors used in modern portable mobile devices like smartphones. AMBA is a registered trademark of ARM Ltd.[1]
AMBA was introduced by ARM in 1996. The first AMBA buses were Advanced System Bus (ASB) and Advanced Peripheral Bus (APB). In its second version, AMBA 2 in 1999, ARM added AMBA High-performance Bus (AHB) that is a single clock-edge protocol. In 2003, ARM introduced the third generation, AMBA 3, including AXI to reach even higher performance interconnect and the Advanced Trace Bus (ATB) as part of the CoreSight on-chip debug and trace solution. In 2010 the AMBA 4 specifications were introduced starting with AMBA 4 AXI4, then in 2011[2] extending system wide coherency with AMBA 4 ACE. In 2013[3] the AMBA 5 CHI (Coherent Hub Interface) specification was introduced, with a re-designed high-speed transport layer and features designed to reduce congestion.
The AMBA specification defines an on-chip communications standard for designing high-performance embedded microcontrollers. It is supported by ARM Limited with wide cross-industry participation.
The AMBA 5 specification defines the following buses/interfaces:
The AMBA 4 specification defines following buses/interfaces:
AMBA 3 specification defines four buses/interfaces:
AMBA 2 specification defines three buses/interfaces:
AMBA specification (First version) defines two buses/interfaces:
The timing aspects and the voltage levels on the bus are not dictated by the specifications.
ACE, defined as part of the AMBA 4 specification, extends AXI with additional signalling introducing system wide coherency.[4] This system coherency allows multiple processors to share memory and enables technology like ARM's big.LITTLEprocessing. The ACE-Lite protocol enables one-way aka IO coherency, for example a network interface that can read from the caches of a fully coherent ACE processor.
AXI, the third generation of AMBA interface defined in the AMBA 3 specification, is targeted at high performance, high clock frequency system designs and includes features that make it suitable for high speed sub-micrometer interconnect:
AHB is a bus protocol introduced in Advanced Microcontroller Bus Architecture version 2 published by ARM Ltd company.
In addition to previous release, it has the following features:
A simple transaction on the AHB consists of an address phase and a subsequent data phase (without wait states: only two bus-cycles). Access to the target device is controlled through a MUX (non-tristate), thereby admitting bus-access to one bus-master at a time.
AHB-Lite is a subset of AHB formally defined in the AMBA 3 standard. This subset simplifies the design for a bus with a single master.
APB is designed for low bandwidth control accesses, for example register interfaces on system peripherals. This bus has an address and data phase similar to AHB, but a much reduced, low complexity signal list (for example no bursts).
