DVB 技术已经远远不是Digital Video Boardcasting 那么简单了,DVB = Digital Video Broadcasting Project
DTMB,ATSC,DVB-T,DVB-T2是目前世界上主要的四种DVB标准,其中DTMB在中国
http://www.dvb.org/technology/standards/
DVB produces specifications which are subsequently standardised in one of the European statutory standardisation bodies, usually the European Telecommunications Standards Institute (ETSI). ETSI, the Centre for Electrotechnical Standards (CENELEC) and the European Broadcasting Union (EBU) have formed a joint technical committee (JTC) to handle the DVB family of standards. In this section you will find the references for all DVB standards and specifications. The standards can be downloaded directly, free of charge, from the ETSI website.
ETSI Publications:首先ETSI出版本身的分类:
typically a set of guidelines for the implementation of a more normative(规范的) specification or standard. A TR is approved by the ETSI Technical Committee which proposes the document.
a document which can contain normative text, i.e. mandatory text such as "shall".
A TS is approved by the ETSI Technical Committee which proposes the document,
and as such might lack some of the weight associated with the following publications. A DVB TS is generally a stepping stone to a more stable document(s).
a document approved by the entire ETSI membership, not just the Technical Committee proposing it. It is a more stable document, than either a TR or a TS.
the highest ranking ETSI publication approved by the national standards organisations of Europe. An EN is a publication which can be and often is included in European and national legislation.
From time to time, DVB publishes documents following their approval by its Steering驾驶 Board: the BlueBooks.
In practice, these are either commercial requirements documents, policy statements, or technical specifications which are in the process of being standardised.
In the latter case, DVB has decided that there is value in the rapid publication of draft specifications as BlueBooks, pending their formal standardisation.
BlueBooks are subject to modification and a published ETSI standard takes precedence over (地位优于)its corresponding BlueBook.
Standard References
Click on the links below to jump directly to the category for which you seek references.
Conditional Access
Content Protection Copy Management
Interactivity
Interfacing
Internet Protocol
Measurement
Middleware
Multiplexing
Source Coding
Subtitling
Transmission
3D-TV
1 http://www.dvb.org/index.xml
2
