在安装各种linux发行版本,经常用到的vm tools的安装问题:...
If an earlier version of VMware Tools is installed, the menu item is Update VMware Tools. If the current version is installed, the menu item is
Reinstall VMware Tools.
Some Linux distributions use different device names or organize the /dev directory differently. If your CD-ROM drive is not
/dev/cdrom or if the mount point for a CD-ROM is not
/mnt/cdrom, modify the command to reflect the conventions used by your distribution.
The value <x.x.x> is the product version number and
<yyyy> is the build number of the product release.
Respond to the questions the command-line wizard displays on the screen. Press Enter to accept the default value. The configuration file,
vmware-config-tools.pl, runs after the installer file finishes running.
