最近到一家公司面试嵌入式职位【公司名字就不提了】,被这个问题给问蒙了:
他问:
UCOS 和 Linux 那个是抢占式的操作系统:
一直认为没去研究过这个概念,结果混乱答到:linux应该是强占式的吧?
结果,面试官回答,错,ucos是,而linux不是。。。。Linux是按照时间片輪巡。。。
汗,这个职位本来很适合,结果黄了
今天研究了一下定义:简单讲,
所谓非抢占,就是如果在当前进程被中断剥夺控制权后,无论如何都能回到原来的任务。任务有优先级别。可用不可重入函数
反之,抢占任务就是当前低优先级别的任务会被高优先级别任务打断。
至于 linux
Linux抢占式内核就是由Robert Love修改实现的。在他的书中有如下描述:
User Preemption
User preemption occurs when the kernel is about to return to user-space,
need_resched is set, and therefore, the scheduler is invoked. If the
kernel is returning to user-space, it knows it is in a safe quiescent
state. In other words, if it is safe to continue executing the current
task, it is also safe to pick a new task to execute. Consequently,
whenever the kernel is preparing to return to user-space either on
return from an interrupt or after a system call, the value of
need_resched is checked. If it is set, the scheduler is invoked to
select a new (more fit) process to execute. Both the return paths for
return from interrupt and return from system call are architecture
dependent and typically implemented in assembly in entry.S (which, aside
from kernel entry code, also contains kernel exit code).
In short, user preemption can occur
When returning to user-space from a system call
When returning to user-space from an interrupt handler
Kernel Preemption
The Linux kernel, unlike most other Unix variants and many other
operating systems, is a fully preemptive kernel. In non-preemptive
kernels, kernel code runs until completion. That is, the scheduler is
not capable of rescheduling a task while it is in the kernelkernel code
is scheduled cooperatively, not preemptively. Kernel code runs until it
finishes (returns to user-space) or explicitly blocks. In the 2.6
kernel, however, the Linux kernel became preemptive: It is now possible
to preempt a task at any point, so long as the kernel is in a state in
which it is safe to reschedule.
So when is it safe to reschedule? The kernel is capable of preempting a
task running in the kernel so long as it does not hold a lock. That is,
locks are used as markers of regions of non-preemptibility. Because the
kernel is SMP-safe, if a lock is not held, the current code is reentrant
and capable of being preempted.
The first change in supporting kernel preemption was the addition of a
preemption counter, preempt_count, to each process's thread_info. This
counter begins at zero and increments once for each lock that is
acquired and decrements once for each lock that is released. When the
counter is zero, the kernel is preemptible. Upon return from interrupt,
if returning to kernel-space, the kernel checks the values of
need_resched and preempt_count. If need_resched is set and preempt_count
is zero, then a more important task is runnable and it is safe to
preempt. Thus, the scheduler is invoked. If preempt_count is nonzero, a
lock is held and it is unsafe to reschedule. In that case, the interrupt
returns as usual to the currently executing task. When all the locks
that the current task is holding are released, preempt_count returns to
zero. At that time, the unlock code checks whether need_resched is set.
If so, the scheduler is invoked. Enabling and disabling kernel
preemption is sometimes required in kernel code and is discussed in
Chapter 9.
Kernel preemption can also occur explicitly, when a task in the kernel
blocks or explicitly calls schedule(). This form. of kernel preemption
has always been supported because no additional logic is required to
ensure that the kernel is in a state that is safe to preempt. It is
assumed that the code that explicitly calls schedule() knows it is safe
to reschedule.
Kernel preemption can occur
When an interrupt handler exits, before returning to kernel-space
When kernel code becomes preemptible again
If a task in the kernel explicitly calls schedule()
If a task in the kernel blocks (which results in a call to schedule())
综述:
所谓Linux是不是抢占式应该是伪命题,下次,在有那个面试官自以为是的吓唬你,你就反问:
您知道Robert Love么,他如果不知道,你就教育一下他:上面的内容,然后告诉他,纠结抢占式和非抢占式意义不大。或者教育一下,您知道什么是抢占式么?
正真系统嵌入式构架考虑的还是系统整个应用的需求
ref:
1 ucosll the real time kernel by jean j .labrosse / 贝贝翻译
2 Robert Love the linux kernel designer
3 small rtos51 立功兄
4 http://www.oldlinux.org/oldlinux/viewthread.php?tid=3024
