Change access permissions, change mode.
Syntax chmod [Options]... Mode [,Mode]... file... chmod [Options]... Numeric_Mode file... chmod [Options]... --reference=RFile file... Options -f, --silent, --quiet suppress most error messages -v, --verbose output a diagnostic for every file processed -c, --changes like verbose but report only when a change is made --reference=RFile use RFile's mode instead of MODE values -R, --recursive change files and directories recursively --help display help and exit --version output version information and exit
chmod changes the permissions of each given file according to mode, where mode describes the permissions to modify. Mode can be specified with octal numbers or with letters. Using letters is easier to understand for most people.
Permissions: |
owner | group | other |
read | |||
write | |||
execute |
From one to four octal digits
Any omitted digits are assumed to be leading zeros.
The first digit = selects attributes for the set user
ID (4) and set group ID (2) and save text image (1)S
The second digit = permissions for the user who owns the file: read (4), write
(2), and execute (1)
The third digit = permissions for other users in the file's group: read (4),
write (2), and execute (1)
The fourth digit = permissions for other users NOT in the file's group: read
(4), write (2), and execute (1)
The octal (0-7) value is calculated by adding up the values
for each digit
User (rwx) = 4+2+1 = 7
Group(rx) = 4+1 = 5
World (rx) = 4+1 = 5
chmode mode = 0755
Examples
chmod 400 file - Read by owner
chmod 040 file - Read by group
chmod 004 file - Read by world
chmod 200 file - Write by owner
chmod 020 file - Write by group
chmod 002 file - Write by world
chmod 100 file - execute by owner
chmod 010 file - execute by group
chmod 001 file - execute by world
To combine these, just add the numbers together:
chmod 444 file - Allow read permission to owner and group and world
chmod 777 file - Allow everyone to read, write, and execute file
Symbolic Mode
The format of a symbolic mode is a combination of the letters +-= rwxXstugoa
Multiple symbolic operations can be given, separated by commas.
The full syntax is [ugoa...][[+-=][rwxXstugo...]...][,...] but this is explained below.
A combination of the letters ugoa controls which users' access to the
file will be changed:
User letter The user who owns it u Other users in the file's Group g Other users not in the file's group o
All users a
If none of these are given, the effect is as if a were
given, but bits that are set in the umask are not affected.
All users a is effectively
user + group + others
The operator '+' causes the permissions selected to be added to the existing
permissions of each file; '-' causes them to be removed; and '=' causes them
to be the only permissions that the file has.
The letters 'rwxXstugo' select the new permissions for the affected users:
Permission letter Read r Write w Execute (or access for directories) x Execute only if the file is a directory
(or already has execute permission for some user)X Set user or group ID on execution s Save program text on swap device t
The permissions that the User who owns the file currently has for itu The permissions that other users in the file's Group have for it g Permissions that Other users not in the file's group have for it o
Examples
Deny execute permission to everyone:
chmod a-x file
Allow read permission to everyone:
chmod a+r file
Make a file readable and writable by the group and others:
chmod go+rw file
Make a shell script. executable by the user/owner
$ chmod u+x myscript.sh
Allow everyone to read, write, and execute the file and turn on the set group-ID:
chmod =rwx,g+s file
Notes:
When chmod is applied to a directory:
read = list files in the directory
write = add new files to the directory
execute = access files in the directory
chmod never changes the permissions of symbolic links. This is not a problem
since the permissions of symbolic links are never used. However, for each symbolic
link listed on the command line, chmod changes the permissions of the pointed-to
file. In contrast, chmod ignores symbolic links encountered during recursive
directory traversals.
This page documents the GNU version of chmod.
"Whether a pretty woman grants or withholds her favours, she always likes to be asked for them" - Ovid (Ars Amatoria)
Related:
access - Determine whether a file can be accessed
ls -l - List current permissions: --
u (owner) -- g (group) -- O (Other)
chgrp - Change group ownership
chown - Change file owner and group
bash syntax - Permissions
Equivalent Windows command: CACLS - Change file permissions
