hsy75] 如何查询这些命令的帮助,最好的方式就是如下:
直接在dos command 窗户输入:
for /? >for.txt 在for.txt 中你就会得到帮助了:
【hsy75案 以下是直接从HELP文件中拷贝出来的例子和解释,这里稍微做了点分析】
helps for for command:
如下:
Runs a specified command for each file in a set of files.
FOR %variable IN (set) DO command [command-parameters] %variable Specifies a
single letter replaceable parameter.
(set) Specifies a set of one or more
files. Wildcards may be used.
command Specifies the command to carry out for each file.
command-parameters
Specifies parameters or switches for the specified command.
To use the FOR command in a batch program, specify %%variable instead
of %variable. Variable names are case sensitive, so %i is different
from %I.
If Command Extensions are enabled, the following additional
forms of the FOR command are supported:
FOR /D %variable IN (set) DO command [command-parameters]
If set contains wildcards, then specifies to match against directory
names instead of file names.
FOR /R [[drive:]path] %variable IN (set) DO command [command-parameters]
Walks the directory tree rooted at [drive:]path, executing the FOR
statement in each directory of the tree. If no directory
specification is specified after /R then the current directory is
assumed. If set is just a single period (.) character then it
will just enumerate the directory tree.
FOR /L %variable IN (start,step,end) DO command [command-parameters]
The set is a sequence of numbers from start to end, by step amount.
So (1,1,5) would generate the sequence 1 2 3 4 5 and (5,-1,1) would
generate the sequence (5 4 3 2 1)
FOR /F ["options"] %variable IN (file-set) DO command [command-parameters]
FOR /F ["options"] %variable IN ("string") DO command [command-parameters]
FOR /F ["options"] %variable IN ('command') DO command [command-parameters]
or, if usebackq option present:
FOR /F ["options"] %variable IN ('string') DO command [command-parameters]
FOR /F ["options"] %variable IN (`command`) DO command [command-parameters]
filenameset is one or more file names. Each file is opened, read
and processed before going on to the next file in filenameset.
Processing consists of reading in the file, breaking it up into
individual lines of text and then parsing each line into zero or
more tokens. The body of the for loop is then called with the
variable value(s) set to the found token string(s). By default,
/F passes the first blank separated token from each line of each file.
Blank lines are skipped. You can override the default parsing
behavior. by specifying the optional "options" parameter. This
is a quoted string which contains one or more keywords to specify
different parsing options. The
keywords are:
eol=c - specifies an end of line
comment character (just one)
skip=n - specifies the number of lines to skip at the
beginning of the file.
delims=xxx - specifies a delimiter set. This replaces the
default delimiter set of space and tab.
【hsy75案】delims 设置了出空格和TAB以外的参数限制分割符号,这个非常有用,当从配置文件尤其是linux的文件配置里面拿出配置的参数应用于当前的bat文件的时候
往往会遇到各种分割符号定义,比如( ,
tokens=x,y,m-n - specifies which tokens【代换】 from each line are to
be passed to the for body for each iteration.
This will cause additional variable names to
be allocated. The m-n form. is a range,
specifying the mth through the nth tokens. If
the last character in the tokens= string is an
asterisk【星号】, then an additional variable is
allocated and receives the remaining text on
the line after the last token parsed.
usebackq - specifies that the new semantics are in force,
where a back quoted string is executed as a
command and a single quoted string is a
literal string command and allows the use of
double quotes to quote file names in
filenameset.
Some examples might help:
FOR /F "eol=; tokens=2,3* delims=, " %i in (myfile.txt) do @echo %i %j %k would parse 【解析】each line in myfile.txt, ignoring lines that begin with
a semicolon【分号】, passing the 2nd and 3rd token from each line to the for
body, with tokens delimited by commas and/or spaces【hsy75案,这里逗号分号都是分割符号了】. Notice the for
body statements reference %i to get the 2nd token, %j to get the
3rd token, and %k to get all remaining tokens after the 3rd【hsy75案,这里表示的bat的临时替换变量,依次按顺序获取文件分割符号分割好的字符参数】.
For file names that contain
spaces, you need to quote the filenames with
double quotes【hsy75案,因为空格是默认的分割符,所以如果你的字符参数含有空格,就必须用双引号括起来】. In order to use double quotes in this manner, you also
need to use the usebackq option, otherwise the double quotes will be
interpreted as defining a literal string to parse.
%i is explicitly declared in the for statement and the %j and %k
are implicitly declared via the tokens= option. You can specify up
to 26 tokens via the tokens= line, provided it does not cause an
attempt to declare a variable higher than the letter 'z' or 'Z'.
Remember, FOR variables are single-letter, case sensitive, global,
and you can't have more than 52 total active at any one time.
You can also use the FOR /F parsing logic on an immediate string, by
making the filenameset between the parenthesis a quoted string,
using single quote characters. It will be treated as a single line
of input from a file and parsed.
Finally, you can use the FOR /F command to parse the output of a
command. You do this by making the filenameset between the
parenthesis a back quoted string. It will be treated as a command
line, which is passed to a child CMD.EXE and the output is captured
into memory and parsed as if it was a file. So the following
example:
FOR /F "usebackq delims==" %i IN (`set`) DO @echo %i
would enumerate the environment variable names in the current
environment.
In addition, substitution of FOR variable references has been enhanced.
You can now use the following optional syntax:
%~I - expands %I removing any surrounding quotes (")
%~fI - expands %I to a fully qualified path name
%~dI - expands %I to a drive letter only
%~pI - expands %I to a path only
%~nI - expands %I to a file name only
%~xI - expands %I to a file extension only
%~sI - expanded path contains short names only
%~aI - expands %I to file attributes of file
%~tI - expands %I to date/time of file
%~zI - expands %I to size of file
%~$PATH:I - searches the directories listed in the PATH
&n
ref :http://www.jb51.net/article/7131_5.htm
