1 NIT 基本概念:what is NIT used for?Network Information Table (NIT):
It is intended to provide information about the
physical network.
【hsy75 但是,到底是那些physical信息呢,接下来讨论!】
1 .1
NIT的作用主要是对多路
传输流的识别,NIT提供多路传输流,
物理网络及网络传输的相关的一些信息,如用于
调谐的频率信息以及编码方式。
调制方式等参数方面的信息。根据此信息设置IRD(Integrated Receiver Decoder)可以进行多路传输流之间的切换。
【hsy75案】说白了就是方便快速做查找物理的网络和切换:1.2 NIT 被
EPG的应用所要求:
1.3 NIT 概括地说:中国电子顶级开发网--电子设计讨论、博客、超人气的电子工程师资料分享平台NB5Kj?(`;d
)v,U[y-@)wW51552The first entry in the PAT (program 0) is reserved for network data and
contains the PID of the network information table (NIT).
【hsy75案】PAT的表0 包含了NIT的索引:
The NIT
includes information of other transport
iPb*@\?g streams that may be available, for example,by
1 tuning to a different RF channel or
2 satellite.
Each transport stream may
include a descriptor that specifies the radio frequency, satellite
orbital position, etc.
【hsy75案】NIT 主要包含网络的调谐信息,包含频率,卫星的位置等等。In MPEG-2,
only the
NIT is mandatory for this purpose.
In DVB, additional metadata, known
as DVB-SI, is used, and NIT is considered to be part of DVB-SI.
Therefore, the term PSI/SI is a commonly used term.
中国电子顶级开发网--电子设计讨论、博客、超人气的电子工程师资料分享平台6~+k#[a
u`x【hsy75案】NIT 在DVB 中基本上可以被DVB-SI 取代。
2 NIT 的应用和结构:En300468
The NIT (see table 3) conveys information relating to the physical organization of the multiplexes/TSs carried via a given network, and the characteristics of the network itself.
The combination of
original_network_id and
transport_stream_id allow
each TS to be
uniquely identified throughout the ETS application area.
【hsy75案】每个TS都可以被唯一的标识Networks are assigned
individual network_id values, which serve as unique identification codes for networks. The allocation of these codes may be found in ETR 162 [6].
In the case that the NIT is transmitted on the network on which the TS was
originated(appear for the first time in a particular place or situation
the
network_id and the
original_network_id shall take the same value.
【hsy75案】每个Networks有自己独立的标识:network_id,当NIT一开始传输时,两个值的标识应该相同的值。Guidelines for the processing of SI at transitions between delivery media boundaries, e.g. from satellite to cable or SMATV systems, can be found in ETR 211 [7].
IRDs may be able to
store the NIT information in non-volatile memory in order to minimize the access time when switching between channels ("channel hopping").
It is also possible to transmit a NIT for other networks in addition to the actual network.
Differentiation between the NIT for the actual network and the NIT for other networks is achieved using different
table_id values (see table 2).
标准定义的表的值如下:
0x40 network_information_section - actual_network0x41 network_information_section - other_network【hsy75案】一个TS流传输其他网络的信息,可以通过NIT others来进行,不同的是NIT的table_id不同。下图是一个实际流的例子:
The NIT shall be segmented into
network_information_sections using the syntax of table 1.
NIT, ST 0x0010Any sections forming part of an NIT shall be transmitted in TS packets with a PID value of 0x0010.
Any sections of the NIT which describe the actual network
(that is, the network of which the TS containing the NIT is a part) shall have the table_id value
0x40
with the network_id field taking the value assigned to the actual network in ETR 162 [6].
Any sections of an NIT which refer to a network other than the actual network shall take a table_id value of 0x41 and the network_id shall take the value
allocated to the other network in ETR 162 [6].
ref:
1 video demystify
2 En300468
