DiSEqC (Digital Satellite Equipment Control), pronounced "Die-Sec", is a special communication protocol for use between a satellite receiver and a device such as a multi-dish switch or a small[1] dish antenna rotor. DiSEqC was developed by European satellite provider Eutelsat, which now acts as the standards agency for the protocol.
DiSEqC relies only upon a coaxial cable to transmit both bidirectional data/signals and power. DiSEqC is commonly used to control switches and motors, and is more flexible than 13/18 volt and 22 kHz tone or ToneBurst/MiniDiSEqC techniques. DiSEqC is also compatible with the actuators used to rotate large C band dishes if used with a DiSEqC positioner. Despite its name, it has been used on fully analogue or only partially digital-capable (Astra Digital Radio) satellite receivers.
A number of variations of DiSEqC exist:
All four variations were standardized by February 1998, prior to general use of digital satellite television. The later versions are backwards compatible with the lower revisions, but the lower revisions are, as might be expected, not forwards compatible with the higher revision numbers. 1.x and 2.x versions are both backwards and forwards compatible. This table shows what works and what does not:
1.0 switch | 1.1 switch | 1.2 motor | 2.0 switch | 2.1 switch | 2.2 motor | |
1.0 receiver | yes | no | no | yes | no | no |
1.1 receiver | yes | yes | no | yes | yes | no |
1.2 receiver | yes | yes | yes | yes | yes | yes |
2.0 receiver | yes | no | no | yes | no | no |
2.1 receiver | yes | yes | no | yes | yes | no |
2.2 receiver | yes | yes | yes | yes | yes | yes |
Do note that a 1.x receiver will not be able to receive communication from a switch or motor. Usually this is not important, as the switch or motor can be controlled by the receiver without problems.
Eutelsat apparently developed the system to allow satellite users in Continental Europe to switch between the more popular SES Astra satellites at 19.2° east and Eutelsat's own Hot Bird system at 13° east. As a result, the vast majority of European satellite receivers support DiSEqC 1.0 or higher, with the notable exception of all set top boxes manufactured under the Sky Digibox name. All supporting receivers have received certification to carry a logo specifying which variation of DiSEqC they support.
Also often found are the terms DiSEqC 1.3 and 2.3 used by manufacturers and retailers to refer to the use of DiSEqC with other protocols. For example, 1.3 usually refers to a receiver which uses USALS in conjunction with the DiSEqC 1.2 protocol. Such terminology has not been authorised by Eutelsat.
