打工仔小小阳的个人空间 https://blog.eetop.cn/1791140 [收藏] [复制] [分享] [RSS]
GUI Python
已有 178 次阅读| 2024-3-2 14:58 |系统分类:其他
import tkinter as tk
from tkinter import filedialog, messagebox
import os
# 配置文件名
CONFIG_FILE = 'configdemo'
# 读取和修改配置文件
def read_and_modify_config(tt_checked, ss_checked, ff_checked, all_checked, sim_checked, project_entry, cellnamex_entry):
    with open(CONFIG_FILE, 'r') as file:
        lines = file.readlines()
    # 寻找TT_CORNER和SS_CORNER并修改
    modified = False
    for i, line in enumerate(lines):
        if 'TT_CORNER' in line:
            if tt_checked or all_checked:
                lines[i] = line.replace('[0]', '[1]')
            else:
                lines[i] = line.replace('[1]', '[0]')
                modified = True
        elif 'SS_CORNER' in line:
            if ss_checked or all_checked:
            else:
                modified = True
        elif 'FF_CORNER' in line:
            if ff_checked or all_checked:
            else:
                modified = True
        elif 'PRE_OR_POST ' in line:
            if sim_checked :
            else:
                modified = True
    # 添加CDL_PATH
    cdl_path = cdl_entry.get()
    if cdl_path and 'CDL_PATH' not in lines:
        # Ensure CDL_PATH is added as a new line
        lines.append('\n')  # Add a new line before CDL_PATH
        lines.append(f'CDL_PATH=[{cdl_path}]\n')
        modified = True
    # 添加model_PATH
    model_path = model_entry.get()
    if model_path and 'MODEL_PATH' not in lines:
        # Ensure MODEL_PATH is added as a new line
        lines.append('\n')  # Add a new line before MODEL_PATH
        lines.append(f'MODEL_PATH=[{model_path}]\n')
        modified = True
    # 添加或修改project
    project_value = project_entry.get()
    if project_value and 'project' not in lines:
        lines.append(f'project={project_value}\n')
        modified = True
    # 添加或修改cell_namex
    cellnamex_value = cellnamex_entry.get()
    if cellnamex_value and 'cellnamex' not in lines:
        lines.append(f'cellnamex={cellnamex_value}\n')
        modified = True
    # 如果文件被修改,则另存为新文件
    if modified:
        new_file_name = f"config"  # 新文件名,可以是任何您选择的名称
        with open(new_file_name, 'w') as new_file:  # 使用新文件名打开文件以写入
            new_file.writelines(lines)
        messagebox.showinfo('Success', f'Modified config saved to {new_file_name}')
# 文件选择按钮回调函数
def select_file():
    filepath = filedialog.askopenfilename()
    if filepath:
        cdl_entry.delete(0, tk.END)
        cdl_entry.insert(0, filepath)
def select_model_file():
    file_path = filedialog.askopenfilename()
    if file_path:
       model_entry.delete(0, tk.END)
       model_entry.insert(0, file_path)
# 保存按钮回调函数
# def save_changes():
#    read_and_modify_config(tt_check.get(), ss_check.get(), all_check.get(), project_entry, cellnamex_entry)
def save_changes():
    # 假设这些是从GUI中获取的checkbox和输入框的值
    tt_checked = tt_check.get()
    ss_checked = ss_check.get()
    ff_checked = ff_check.get()
    all_checked = all_check.get()
    sim_checked = sim_check.get()
# 创建GUI窗口
root = tk.Tk()
root.title('Config Modifier')
root.geometry("300x200")  # 设置窗口大小
root.configure(background='lightgray')  # 设置窗口背景色
# 添加 "Corner" Label
corner_label = tk.Label(root, text="Corner:", font=('Arial', 12))
corner_label.pack(pady=(10, 0), anchor=tk.W)  # 使用anchor=tk.W来确保它靠左对齐
# 添加包含勾选框的Frame
frame = tk.Frame(root)
frame.pack(pady=(0, 10), anchor=tk.N)  # 使用anchor=tk.N来确保它靠北对齐,并设置下方的间距
tt_check = tk.BooleanVar(value=False)
tt_check_entry = tk.Checkbutton(frame, text='TT', variable=tt_check)
tt_check_entry.pack(side=tk.LEFT, padx=5)
ss_check = tk.BooleanVar(value=False)
ss_check_entry = tk.Checkbutton(frame, text='SS', variable=ss_check)
ss_check_entry.pack(side=tk.LEFT, padx=5)
ff_check = tk.BooleanVar(value=False)
ff_check_entry = tk.Checkbutton(frame, text='FF', variable=ff_check)
ff_check_entry.pack(side=tk.LEFT, padx=5)
all_check = tk.BooleanVar(value=False)
all_check_entry = tk.Checkbutton(frame, text='ALL', variable=all_check)
all_check_entry.pack(side=tk.LEFT, padx=5)
# 添加 "sim" Label 和 "POST" 勾选框到同一个Frame中
sim_frame = tk.Frame(root)
sim_frame.pack(pady=(0, 10), anchor=tk.N)  # 使用anchor=tk.N来确保它靠北对齐,并设置下方的间距
sim_label = tk.Label(sim_frame, text="POST :", font=('Arial', 12))
sim_label.pack(side=tk.LEFT)
sim_check = tk.BooleanVar(value=False)
sim_check_entry = tk.Checkbutton(sim_frame, text='POST', variable=sim_check)
sim_check_entry.pack(side=tk.LEFT, padx=5)
# 由于sim_frame和frame都在root中,并且都使用anchor=tk.N,sim_frame会出现在frame上方
# 文件选择按钮和输入框
cdl_path_button = tk.Button(root, text='Select CDL Path', command=select_file)
cdl_path_button.pack(pady=5)
cdl_entry = tk.Entry(root)
cdl_entry.pack(pady=5)
model_path_button = tk.Button(root, text='Select MODEL Path', command=select_model_file)
model_path_button.pack(pady=5)
model_entry = tk.Entry(root)
model_entry.pack(pady=5)
# 建立project对应按钮及输入框
project_entry = tk.StringVar()
project_label = tk.Label(root, text="Project:", font=('Arial', 12))
project_label.pack()
project_entry_field = tk.Entry(root, textvariable=project_entry)
project_entry_field.pack()
# 添加提示信息的标签
project_hint_label = tk.Label(root, text="Rup, Rdown, tran...")
project_hint_label.pack()
# 建立cellname对应按钮及输入框
cellnamex_entry = tk.StringVar()
cellnamex_label = tk.Label(root, text="Cellname:", font=('Arial', 12))
cellnamex_label.pack()
cellnamex_entry_field = tk.Entry(root, textvariable=cellnamex_entry)
cellnamex_entry_field.pack()
# 添加提示信息的标签
cellnamex_hint_label = tk.Label(root, text="retion X or Y")
cellnamex_hint_label.pack()
# 保存按钮
save_button = tk.Button(root, text='Save', command=save_changes)
save_button.pack(pady=5)
# 运行GUI
root.mainloop()
  • 13
GMT+8, 2024-5-28 15:58 , Processed in 0.028064 second(s), 14 queries , Gzip On, Redis On.
