ASIC :
Application Specific Integrated CircuitAOCV : Advanced on-chip Variation(back_end STA)
CPLD :
Complex Programmable Logic Device
CRPR: clock reconveregence pessimism removal(Synopysis, same with CPPR)
CPPR: clock path pessimism removal(Cadence, same with CRPR)
DDR : Double Data Rate.
DLL: Delay Locked Loop.
FSM: Finite State Machines
FPGA :
Field Programmable Gate ArrayIoff : When gate close and the source/drain have high voltage, Ioff will be exists.
LVF : Liberty Variation Format
LVF is a
parametric on-chip variation modeling. Given some statistical parameters
such as sigma, LVF can calculate the variation by using statistical
method
NMOS: N-channel Metal Oxide Semiconductor
OCV : On-chip Variation
PMOS: P-channel Metal Oxide Semiconductor
POCV : Parametric on-chip Variation(back_end STA)
PVT : Process, Voltage, Temperature
QTM : Quick Time Mode
STA : Static Timing Analysis
