1. Parse report_timing command (1) What's "time borrowed from endpoint" and "time given to startpoint"?
Link:http://www.xilinx.com/support/answers/56877.html
Time borrowed from endpoint:
In a path where
the endpoint is a latch device, the borrowing time refers to the time
from the clock cycle of the latch that is expended by the previous
synchronous device. Or in other words, given that a latch is active
during a whole clock pulse, if the path between the previous synchronous
device and the latch produce a variation of the capturing data at the
latch after the latch is enabled, this will produce a borrowing time
from the latch.
For example, in the following two-stage latch
base design, the combinational logic block between Latch1 and Latch2 may
have more delay than the delay between Latch2 and Latch3. To resolve
this discrepancy, the first stage can borrow time from the second clock
cycle. In this event, the second clock cycle is left with less time to
accommodate the combinational logic block between Latch2 and Latch3
Time given to startpoint:
The above picture shows
clearly the meaning of this parameter. It would be the path delay from
the synchronous element until the latch
(2) What's "time borrow from startpoint" and "time given to endpoint"?
(3) What's clock latency difference?
The clock rising and falling edge propagate have different delay.
If the (0,468) delay to (10, 488), then the clock latency difference is 10.
a=(10-0=10), b=(488-468=20), clock latency difference=b-a=10.
(4) Why sometimes the "actual clock borrow time" is a negative value?
Because the CK -> Q arc and D -> Q arc have different values, when D -> Q(200ps) and CK -> Q(100ps), when D change at before CK open with 50ps, then the actual borrow time is -50ps(100-200+50)
2. Question about STA(1) What's "Delay based Design"?
It's different with "Clock based Design" and It's use delay to generate the skew between two FFs or latchs.
(2) How to do Setup/Hold violation check?
1st latch clock sequence {1o1,1c1,1o2,1c2,1o3,1c3}, 2nd latch clock sequence {2o1,2c1,2o2,2c2,2o3,2c3}, and have delay between those two latch.
setup: 1o1 data to 2o1 clock
hold: 2o1 data to 2c1 clock
(3) How to check latch setup and hold violation?
1) Check two latch setup(1st latch and 2nd latch);
2) 1st latch(open edge) launch the data;
3) Find the close edge of the 2nd latch;
4) Move to the forward open edge of the 2nd latch to check setup.
(4) What's CRPR(clock reconveregence pessimism removal)?
If data and clock pass through the same path, the data path use the max delay to calculate, while the clock path use the min delay to calculate. It's impossible use two delay value to one common path.
In the common path, CRPR_value=data_path_delay - clock_path_delay, then in the reports, CRPR_value was added to the clock path.
