---1.1 Transaction-Level Modeling
1.A model of time
2.Abstraction Methods of communication between concurrent processes
3.Rules for process activation
Abstract time
The time abstraction in a simulator refers to how often the entire design state is consistent
Abstract data
Data refers to the objects communicated between components.
Abstract function
The function of a model is the set of all things it must do at each event.
---1.2 Definition of a Transaction
A transaction is a quantum of activity that occurs in a design bounded by time.(This is the most general definition of a transaction)
A transaction is a single transfer of control or data between two entities.(This is the hardware-oriented notion of a transaction)
A transaction is a function call.(This definition is the software-oriented notion of a transaction.)
---1.3 Interfaces
The term interface is used in several ways in OVM, each with a slightly different meaning. It’s an unfortunate fact of history that the same word has come to mean so many different things.
SystemVerilog interface
SystemVerilog provides a construct called an interface, which is one of the primary container objects from which you construct a design in SystemVerilog.
Object interface
There are two slight variations of this meaning of interface. (1) Look at a class and determine what tasks and functions are available to the user of the class to operate it.That’s its interface.
(2) The other variation is to refer to a base class that defines the set of tasks and functions available to operate the derived class.
DUT interface
A piece of hardware is typically accessed through its interfaces. In this context, an interface is composed of the pins and protocol used to communicate to the device.
---1.4 TLM Idioms
This section reviews the basic means of transmitting a transaction between components. We’ll examine put, get, and transport forms of transaction communication.
put
In a put configuration, one component sends transactions to another
component. The operation is called a put.
