路科验证(Rocker IC)专注于验证系统思想和前沿工程资讯,拥有一支活跃的技术原创团队,为高校微电子相关专业学生与IC从业人员提供技术食粮。 您可以在手机移动端同步关注微信订阅号“路科验证”。如果您需要联系我们,请发送邮件至 rocker.ic@vip.163.com 或者 bin.rocker.liu@intel.com 。
Synophys SystemVerilog Lab 设计文件
上一篇 / 下一篇  2017-08-27 22:32:33 / 个人分类:Synopsys SV 实验
// control pins:
// input: reset_n - active low reset
// input: clock - master clock input
// input port pins:
// input: frame_n - must be active during whole input packet
// input: valid_n - valid data input
// input: di - the data input
// output: busy_n - tells input that connection is busy
// output port pins:
// output: do - the data output
// output: valido_n - tells output device that "do" contain valid data
// output: frameo_n - active during the whole output packet
// frame. format:
// Frame. start must look like this:
// frame_n: |  1 |  0 |  0 |  0 |  0 |  0 |  0 |  0 |  0 |  0  | ...
// di: |  X | A0 | A1 | A2 | A3 |  1 |  X |  X |  X | D0  | ...
// valid_n: |  X |  X |  X |  X |  X |  X |  1 |  1 |  1 | 0/1 | ...
// note1: frame_n must deasserted at least one cycle between packets.
// note2: address data does not have to wait for busy_n = 1.
// note3: di must wait for busy_n = 1.
// note4: a di is taken by the chip if:  busy_n == 1 && valid_n == 0
// note5: frame_n must be deasserted with the last data bit in the frame.
// note6: once connection is successfully made, busy_n is guaranteed to
//  stay inactive until to the end of the current frame.
module router(
    reset_n, clock, frame_n, valid_n, din, dout, busy_n, valido_n, frameo_n);
input reset_n, clock;
input [15:0] din, frame_n, valid_n;
output [15:0] dout, valido_n, busy_n, frameo_n;
wire reset;
wire [15:0] arb0, arb1, arb2, arb3, arb4, arb5, arb6, arb7;
wire [15:0] di;
wire [15:0] arb8, arb9, arb10, arb11, arb12, arb13, arb14, arb15;
wire [15:0] arb_head, okstep;
tri0 [15:0] doint;
tri1 [15:0] valdoint_n, frameoint_n;
reg [15:0] dout, valido_n, frameo_n;
reg [3:0] arb_head_num;
assign di = din;
assign reset = ~reset_n;
assign arb_head = 1 << arb_head_num;
rtslice rts0(reset,clock,frame_n[0],valid_n[0],di[0],
arb0,arb1,arb_head[0],okstep[0],
doint,busy_n[0],valdoint_n,frameoint_n);
rtslice rts1(reset,clock,frame_n[1],valid_n[1],di[1],
arb1,arb2,arb_head[1],okstep[1],
doint,busy_n[1],valdoint_n,frameoint_n);
rtslice rts2(reset,clock,frame_n[2],valid_n[2],di[2],
arb2,arb3,arb_head[2],okstep[2],
doint,busy_n[2],valdoint_n,frameoint_n);
rtslice rts3(reset,clock,frame_n[3],valid_n[3],di[3],
arb3,arb4,arb_head[3],okstep[3],
doint,busy_n[3],valdoint_n,frameoint_n);
rtslice rts4(reset,clock,frame_n[4],valid_n[4],di[4],
arb4,arb5,arb_head[4],okstep[4],
doint,busy_n[4],valdoint_n,frameoint_n);
rtslice rts5(reset,clock,frame_n[5],valid_n[5],di[5],
arb5,arb6,arb_head[5],okstep[5],
doint,busy_n[5],valdoint_n,frameoint_n);
rtslice rts6(reset,clock,frame_n[6],valid_n[6],di[6],
arb6,arb7,arb_head[6],okstep[6],
doint,busy_n[6],valdoint_n,frameoint_n);
rtslice rts7(reset,clock,frame_n[7],valid_n[7],di[7],
arb7,arb8,arb_head[7],okstep[7],
doint,busy_n[7],valdoint_n,frameoint_n);
rtslice rts8(reset,clock,frame_n[8],valid_n[8],di[8],
arb8,arb9,arb_head[8],okstep[8],
doint,busy_n[8],valdoint_n,frameoint_n);
rtslice rts9(reset,clock,frame_n[9],valid_n[9],di[9],
arb9,arb10,arb_head[9],okstep[9],
doint,busy_n[9],valdoint_n,frameoint_n);
rtslice rts10(reset,clock,frame_n[10],valid_n[10],di[10],
arb10,arb11,arb_head[10],okstep[10],
doint,busy_n[10],valdoint_n,frameoint_n);
rtslice rts11(reset,clock,frame_n[11],valid_n[11],di[11],
arb11,arb12,arb_head[11],okstep[11],
doint,busy_n[11],valdoint_n,frameoint_n);
rtslice rts12(reset,clock,frame_n[12],valid_n[12],di[12],
arb12,arb13,arb_head[12],okstep[12],
doint,busy_n[12],valdoint_n,frameoint_n);
rtslice rts13(reset,clock,frame_n[13],valid_n[13],di[13],
arb13,arb14,arb_head[13],okstep[13],
doint,busy_n[13],valdoint_n,frameoint_n);
rtslice rts14(reset,clock,frame_n[14],valid_n[14],di[14],
arb14,arb15,arb_head[14],okstep[14],
doint,busy_n[14],valdoint_n,frameoint_n);
//rtslicef rts15(reset,clock,frame_n[15],valid_n[15],di[15],
// arb15,arb0,arb_head[15],okstep[15],
// doint,busy_n[15],valdoint_n,frameoint_n);
rtslice rts15(reset,clock,frame_n[15],valid_n[15],di[15],
always @(posedge reset)
begin
    arb_head_num <= 4'b0;
end
always @(posedge clock)
begin
    dout <= doint;
    valido_n <= valdoint_n;
    frameo_n <= frameoint_n;
    if (reset == 1'b0)
    begin
if (okstep[arb_head_num] == 1'b1)
   arb_head_num <= arb_head_num + 1;
    end
end
endmodule  //router
module rtslice(reset,clock,frame_n,valid_n,din,
    iarbin,arbout,arbhead,okstep,
    dout,busy_n,valido_n,frameo_n);
input reset,clock,frame_n,valid_n,din, arbhead;
output busy_n,okstep;
input  [15:0] iarbin;
output [15:0] arbout,dout,valido_n;
inout [15:0] frameo_n;
reg [4:0] addrsf, addrsel;
reg [5:0] addrfsr;
reg din1, busy_n, frame1_n, frame2_n, vald1_n, arbena;
wire [15:0] dout;
wire [15:0] arbin;
wire busy1_n;
wire [4:0] addrsel_g;
reg [3:0] i;
    assign arbin = (arbhead == 1'b1) ? 16'hffff : iarbin;
    assign addrsel_g = (arbena == 1'b1) ? addrsel : 5'h0;
// always @ ( posedge clock)
// begin
    assign dout[0] =
(addrsel_g == 5'h10 && arbin[0] == 1'b1) ? din1 : 1'bZ;
// end
    assign dout[1] =
(addrsel_g == 5'h11 && arbin[1] == 1'b1) ? din1 : 1'bZ;
    assign dout[2] =
(addrsel_g == 5'h12 && arbin[2] == 1'b1) ? din1 : 1'bZ;
    assign dout[3] =
(addrsel_g == 5'h13 && arbin[3] == 1'b1) ? din1 : 1'bZ;
    assign dout[4] =
(addrsel_g == 5'h14 && arbin[4] == 1'b1) ? din1 : 1'bZ;
    assign dout[5] =
(addrsel_g == 5'h15 && arbin[5] == 1'b1) ? din1 : 1'bZ;
    assign dout[6] =
(addrsel_g == 5'h16 && arbin[6] == 1'b1) ? din1 : 1'bZ;
    assign dout[7] =
(addrsel_g == 5'h17 && arbin[7] == 1'b1) ? din1 : 1'bZ;
    assign dout[8] =
(addrsel_g == 5'h18 && arbin[8] == 1'b1) ? din1 : 1'bZ;
    assign dout[9] =
(addrsel_g == 5'h19 && arbin[9] == 1'b1) ? din1 : 1'bZ;
    assign dout[10] =
(addrsel_g == 5'h1a && arbin[10] == 1'b1) ? din1 : 1'bZ;
    assign dout[11] =
(addrsel_g == 5'h1b && arbin[11] == 1'b1) ? din1 : 1'bZ;
    assign dout[12] =
(addrsel_g == 5'h1c && arbin[12] == 1'b1) ? din1 : 1'bZ;
    assign dout[13] =
(addrsel_g == 5'h1d && arbin[13] == 1'b1) ? din1 : 1'bZ;
    assign dout[14] =
(addrsel_g == 5'h1e && arbin[14] == 1'b1) ? din1 : 1'bZ;
    assign dout[15] =
(addrsel_g == 5'h1f && arbin[15] == 1'b1) ? din1 : 1'bZ;
    assign frameo_n[0] =
(addrsel_g == 5'h10 && arbin[0] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[1] =
(addrsel_g == 5'h11 && arbin[1] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[2] =
(addrsel_g == 5'h12 && arbin[2] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[3] =
(addrsel_g == 5'h13 && arbin[3] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[4] =
(addrsel_g == 5'h14 && arbin[4] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[5] =
(addrsel_g == 5'h15 && arbin[5] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[6] =
(addrsel_g == 5'h16 && arbin[6] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[7] =
(addrsel_g == 5'h17 && arbin[7] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[8] =
(addrsel_g == 5'h18 && arbin[8] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[9] =
(addrsel_g == 5'h19 && arbin[9] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[10] =
(addrsel_g == 5'h1a && arbin[10] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[11] =
(addrsel_g == 5'h1b && arbin[11] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[12] =
(addrsel_g == 5'h1c && arbin[12] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[13] =
(addrsel_g == 5'h1d && arbin[13] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[14] =
(addrsel_g == 5'h1e && arbin[14] == 1'b1) ? frame1_n : 1'bZ;
    assign frameo_n[15] =
(addrsel_g == 5'h1f && arbin[15] == 1'b1) ? frame1_n : 1'bZ;
    assign valido_n[0] =
(addrsel_g == 5'h10 && arbin[0] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[1] =
(addrsel_g == 5'h11 && arbin[1] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[2] =
(addrsel_g == 5'h12 && arbin[2] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[3] =
(addrsel_g == 5'h13 && arbin[3] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[4] =
(addrsel_g == 5'h14 && arbin[4] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[5] =
(addrsel_g == 5'h15 && arbin[5] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[6] =
(addrsel_g == 5'h16 && arbin[6] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[7] =
(addrsel_g == 5'h17 && arbin[7] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[8] =
(addrsel_g == 5'h18 && arbin[8] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[9] =
(addrsel_g == 5'h19 && arbin[9] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[10] =
(addrsel_g == 5'h1a && arbin[10] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[11] =
(addrsel_g == 5'h1b && arbin[11] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[12] =
(addrsel_g == 5'h1c && arbin[12] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[13] =
(addrsel_g == 5'h1d && arbin[13] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[14] =
(addrsel_g == 5'h1e && arbin[14] == 1'b1) ? vald1_n : 1'bZ;
    assign valido_n[15] =
(addrsel_g == 5'h1f && arbin[15] == 1'b1) ? vald1_n : 1'bZ;
    assign arbout[0] =
(addrsel_g != 5'h10 && arbin[0] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[1] =
(addrsel_g != 5'h11 && arbin[1] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[2] =
(addrsel_g != 5'h12 && arbin[2] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[3] =
(addrsel_g != 5'h13 && arbin[3] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[4] =
(addrsel_g != 5'h14 && arbin[4] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[5] =
(addrsel_g != 5'h15 && arbin[5] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[6] =
(addrsel_g != 5'h16 && arbin[6] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[7] =
(addrsel_g != 5'h17 && arbin[7] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[8] =
(addrsel_g != 5'h18 && arbin[8] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[9] =
(addrsel_g != 5'h19 && arbin[9] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[10] =
(addrsel_g != 5'h1a && arbin[10] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[11] =
(addrsel_g != 5'h1b && arbin[11] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[12] =
(addrsel_g != 5'h1c && arbin[12] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[13] =
(addrsel_g != 5'h1d && arbin[13] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[14] =
(addrsel_g != 5'h1e && arbin[14] == 1'b1) ? 1'b1 : 1'b0;
    assign arbout[15] =
(addrsel_g != 5'h1f && arbin[15] == 1'b1) ? 1'b1 : 1'b0;
    assign busy1_n = (arbout != arbin) ? 1'b1 : ~addrsel[4];
    assign okstep  = (arbout == arbin) ? 1'b1 : 1'b0;
    begin
if (reset == 1'b1)
begin
   addrsel <= 5'b0;
   addrfsr  <= 6'b0;
   arbena <= 1'b0;
end
    end
    begin
frame1_n <= frame_n;
frame2_n <= frame1_n;
busy_n <= busy1_n;
din1 <= din;
vald1_n <= valid_n | ~busy_n ;
if (reset == 1'b0)
begin
   if (frame2_n != frame1_n && frame1_n == 1'b1)
   begin // frame. is now inactive
addrsel <= 5'b0; // clear the address register
addrfsr <= 6'b0; // clear the address flag reg.
arbena <= 1'b0;
   end
   else
   begin
   if (addrsel[4] == 1'b1 && frameo_n[addrsel[3:0]] == 1'b1)
arbena <= 1'b1;
   end
   if (frame1_n != frame_n && frame_n == 1'b0)
addrfsr <= 6'b11_1111;
   if (addrfsr[5:4] == 2'b10)
addrsel <= {addrsf[0],addrsf[1],addrsf[2],addrsf[3],addrsf[4]};
   if (addrfsr[4] == 1'b1) addrsf <= (addrsf << 1) | { 4'b0, din1 };
   if (addrfsr[5] == 1'b1) addrfsr <= addrfsr << 1;
end
    end
endmodule  //rtslice
module rtslicef(reset,clock,frame_n,valid_n,din,
reg [5:0] addrfsr;
wire [15:0] dout;
wire [15:0] arbin;
wire busy1_n;
    assign dout[0] =
    assign dout[1] =
    assign dout[2] =
    assign dout[3] =
    assign dout[4] =
    assign dout[5] =
    assign dout[6] =
    assign dout[7] =
    // stuck at x
    assign dout[8] =
// (addrsel_g == 5'h18 && arbin[8] == 1'b1) ? din1 : 1'bZ;
(addrsel_g == 5'h18 && arbin[8] == 1'b1) ? 1'bx : 1'bZ;
    assign dout[9] =
    assign dout[10] =
    assign dout[11] =
    assign dout[12] =
    assign dout[13] =
    assign dout[14] =
    assign dout[15] =
    assign arbout[0] =
    assign arbout[1] =
    assign arbout[2] =
    assign arbout[3] =
    assign arbout[4] =
    assign arbout[5] =
    assign arbout[6] =
    assign arbout[7] =
    assign arbout[8] =
    assign arbout[9] =
    assign arbout[10] =
    assign arbout[11] =
    assign arbout[12] =
    assign arbout[13] =
    assign arbout[14] =
    assign arbout[15] =
    begin
if (reset == 1'b1)
begin
   addrsel <= 5'b0;
   addrfsr  <= 6'b0;
   arbena <= 1'b0;
end
    end
    begin
busy_n <= busy1_n;
din1 <= din;
if (reset == 1'b0)
begin
arbena <= 1'b0;
   end
   else
   begin
arbena <= 1'b1;
   end
end
    end
endmodule  //rtslicef
TAG:
评分:0
我来说两句
显示全部
路科验证
路科验证
日历
« 2017-09-18
     12
3456789
10111213141516
17181920212223
24252627282930
数据统计
  • 访问量: 51967
  • 日志数: 149
  • 建立时间: 2016-06-25
  • 更新时间: 2017-09-12
RSS订阅
Open Toolbar
