1.Set the system shared library search path to include the directory of
the Novas object file for FSDB dumping (5.4 is used as an example).
Solaris/Linux Platforms
> setenv LD_LIBRARY_PATH \
${NOVAS_HOME}/share/PLI/modelsim_pli54/${PLATFORM}:\
$LD_LIBRARY_PATH
2.(Optional) If you want to invoke FSDB commands at the vsim prompt, or
run the ModelSim simulation using interactive mode in Debussy/Verdi,
you must compile the novas_vlog.v file into the design library. You can
find this
Linking Novas Files with Simulators to Enable FSDB Waveform. Dumping
82
Verilog file in the ${NOVAS_HOME}/share/PLI/modelsim_pli??/${PLATFORM} directory.
> vlog -work your_working_lib \
${NOVAS_HOME}/share/PLI/modelsim_pli54/${PLATFORM}/novas_vlog.v
3.to load the FSDB dumper libpli.so (or libpli.sl) into vsim during simulation.
[vsim]
veriuser=libpli.so
