package AMBA is
-- Definitions for AMBA(TM) Advanced High-performance Bus (AHB)
-- Records are defined for the input and output of an AHB Master, as well as
-- for an AHB Slave. These records are grouped in arrays, for scalability,
-- and new records using these arrays are defined for the input and output of
-- an AHB Arbiter/Decoder.
-- The routing of the clock and reset signals defined in the AMBA(TM)
-- Specification is not covered in this package, since being dependent on
-- the clock and reset conventions defined at system level.
-- The HCLK and HRESETn signals are routed separately:
-- HCLK: Std_ULogic; -- rising edge
-- HRESETn: Std_ULogic; -- active low reset
-- The address bus HADDR contains byte addresses. The relation between the
-- byte address and the n-byte data bus HDATA can either be little-endian or
-- big-endian according to the AMBA(TM) Specification.
-- It is recommended that only big-endian modules are implemented using
-- this package. -----------------------------------------------------------------------------
-- Definitions for AMBA(TM) AHB Masters
-- AHB master inputs (HCLK and HRESETn routed separately)
type AHB_Mst_In_Type is
record
HGRANT: Std_ULogic; -- bus grant
HREADY: Std_ULogic; -- transfer done
HRESP: Std_Logic_Vector(1 downto 0); -- response type
HRDATA: Std_Logic_Vector(HDMAX-1 downto 0); -- read data bus
end record;
-- AHB master outputs
type AHB_Mst_Out_Type is
record
HBUSREQ: Std_ULogic; -- bus request
HLOCK: Std_ULogic; -- lock request
HTRANS: Std_Logic_Vector(1 downto 0); -- transfer type
HADDR: Std_Logic_Vector(HAMAX-1 downto 0); -- address bus (byte)
HWRITE: Std_ULogic; -- read/write
HSIZE: Std_Logic_Vector(2 downto 0); -- transfer size
HBURST: Std_Logic_Vector(2 downto 0); -- burst type
HPROT: Std_Logic_Vector(3 downto 0); -- protection control
HWDATA: Std_Logic_Vector(HDMAX-1 downto 0); -- write data bus
end record;
-- Definitions for AMBA(TM) AHB Slaves
-- AHB slave inputs (HCLK and HRESETn routed separately)
type AHB_Slv_In_Type is
record
HSEL: Std_ULogic; -- slave select
HMASTER: Std_Logic_Vector(3 downto 0); -- current master
HMASTLOCK: Std_ULogic; -- locked access HRESP: Std_Logic_Vector(1 downto 0); -- response type
HSPLIT: Std_Logic_Vector(15 downto 0); -- split completion
end record;
-- Definitions for AMBA(TM) AHB Arbiter/Decoder
-- supporting array types
type AHB_Mst_In_Vector is array (Natural range <> ) of AHB_Mst_In_Type;
type AHB_Mst_Out_Vector is array (Natural range <> ) of AHB_Mst_Out_Type;
type AHB_Slv_In_Vector is array (Natural range <> ) of AHB_Slv_In_Type;
type AHB_Slv_Out_Vector is array (Natural range <> ) of AHB_Slv_Out_Type;
-- Auxiliary constant definitions for AMBA(TM) AHB
-- constants for HTRANS (transition type, slave output)
constant HTRANS_IDLE: Std_Logic_Vector(1 downto 0) := "00";
constant HTRANS_BUSY: Std_Logic_Vector(1 downto 0) := "01";
constant HTRANS_NONSEQ: Std_Logic_Vector(1 downto 0) := "10";
constant HTRANS_SEQ: Std_Logic_Vector(1 downto 0) := "11";
-- constants for HBURST (burst type, master output)
constant HBURST_SINGLE: Std_Logic_Vector(2 downto 0) := "000";
constant HBURST_INCR: Std_Logic_Vector(2 downto 0) := "001";
constant HBURST_WRAP4: Std_Logic_Vector(2 downto 0) := "010";
constant HBURST_INCR4: Std_Logic_Vector(2 downto 0) := "011";
constant HBURST_WRAP8: Std_Logic_Vector(2 downto 0) := "100";
constant HBURST_INCR8: Std_Logic_Vector(2 downto 0) := "101";
constant HBURST_WRAP16: Std_Logic_Vector(2 downto 0) := "110";
constant HBURST_INCR16: Std_Logic_Vector(2 downto 0) := "111";
-- constants for HSIZE (transfer size, master output)
constant HSIZE_BYTE: Std_Logic_Vector(2 downto 0) := "000";
constant HSIZE_HWORD: Std_Logic_Vector(2 downto 0) := "001";
constant HSIZE_WORD: Std_Logic_Vector(2 downto 0) := "010";
constant HSIZE_DWORD: Std_Logic_Vector(2 downto 0) := "011";
constant HSIZE_4WORD: Std_Logic_Vector(2 downto 0) := "100";
constant HSIZE_8WORD: Std_Logic_Vector(2 downto 0) := "101";
constant HSIZE_16WORD: Std_Logic_Vector(2 downto 0) := "110";
constant HSIZE_32WORD: Std_Logic_Vector(2 downto 0) := "111"; -----------------------------------------------------------------------------
-- Definitions for AMBA(TM) Advanced Peripheral Bus (APB)
-- Records are defined for the input and output of an APB Slave. These
-- records are grouped in arrays, for scalability, and new records using
-- these arrays are defined for the input and output of an APB Bridge.
-- The PCLK and PRESETn signals are routed separately:
-- PCLK: Std_ULogic; -- rising edge
-- PRESETn: Std_ULogic; -- active low reset
-- The characteristics of the address bus PADDR are undefined in the
-- AMBA(TM) Specification.
-- When implementing modules with this package, it is recommended that the
-- information on the address bus PADDR is interpreted as byte addresses, but
-- it should only be used for 32-bit word addressing, i.e. the value of
-- address bits 0 and 1 should always be logical 0. For modules not
-- supporting full 32-bit words on the data bus PDATA, e.g. only supporting
-- 16-bit halfwords or 8-bit bytes, the addressing will still be word based.
-- Consequently, one halfword or byte will be accessed for each word address.
-- Modules only supporting byte sized data should exchange data on bit 7 to 0
-- on the PDATA data bus. Modules only supporting halfword sized data should
-- exchange data on bit 15 to 0 on the PDATA data bus. Modules supporting
-- word sized data should exchange data on bit 31 to 0 on the PDATA data bus.
-- Constant definitions for AMBA(TM) APB
constant PDMAX: Positive range 8 to 32 := 32; -- data width
constant PAMAX: Positive range 8 to 32 := 32; -- address width
-- Definitions for AMBA(TM) APB Slaves
-- APB slave inputs (PCLK and PRESETn routed separately)
type APB_Slv_In_Type is
record
PSEL: Std_ULogic; -- slave select
PENABLE: Std_ULogic; -- strobe
PADDR: Std_Logic_Vector(PAMAX-1 downto 0); -- address bus (byte)
PWRITE: Std_ULogic; -- write
PWDATA: Std_Logic_Vector(PDMAX-1 downto 0); -- write data bus
end record;
-- APB slave outputs
type APB_Slv_Out_Type is
-- constants for HRESP (response, slave output)
constant HRESP_OKAY: Std_Logic_Vector(1 downto 0) := "00";
constant HRESP_ERROR: Std_Logic_Vector(1 downto 0) := "01";
constant HRESP_RETRY: Std_Logic_Vector(1 downto 0) := "10";
constant HRESP_SPLIT: Std_Logic_Vector(1 downto 0) := "11";
end record;
-- AHB slave outputs
type AHB_Slv_Out_Type is
record
-- Constant definitions for AMBA(TM) AHB
constant HDMAX: Positive range 32 to 1024 := 32; -- data width
constant HAMAX: Positive range 32 to 32 := 32; -- address width
record
PRDATA: Std_Logic_Vector(PDMAX-1 downto 0); -- read data bus
end record;
-- Definitions for AMBA(TM) APB Bridge
type APB_Slv_In_Vector is array (Natural range <> ) of APB_Slv_In_Type;
type APB_Slv_Out_Vector is array (Natural range <> ) of APB_Slv_Out_Type;
end AMBA; --==================================================================--
I think VHDL is a good language for RTL coding , because you can see the AMBA BUS define , which is
like C++ . :) , I like this .
