MetricAnalyzers
Overview
度量分析器监视和记录非功能行为,如延迟,功率利用率和其他与性能相关的测量。
Construction
度量分析仪通常是标准analysis components。它们以一种方式来实现它们的行为,这种方式要么是通过扩展uvm_subscriber的方式要么通过使用analysis imp / exports的方式,这取决于它们观察到的事务流数量。
Example
`uvm_analysis_imp_decl(_BEFORE)
`uvm_analysis_imp_decl(_AFTER)
class delay_analyzer extends uvm_component;
`uvm_component_utils(delay_analyzer)
uvm_analysis_imp_BEFORE #(alu_txn, delay_analyzer) before_export;
uvm_analysis_imp_AFTER #(alu_txn, delay_analyzer) after_export;
real m_before[$];
real m_after[$];
real last_b_time, last_a_time;
real longest_b_delay, longest_a_delay;
function new( string name , uvm_component parent) ;
super.new( name , parent );
last_b_time = 0.0;
last_a_time = 0.0;
endfunction
// Record when the transaction arrives
function void write_BEFORE(alu_txn t);
real delay;
delay = $realtime - last_b_time;
last_b_time = $realtime;
m_before.push_back(delay);
endfunction
function void write_AFTER(alu_txn t);
real delay;
delay = $realtime - last_a_time;
last_a_time = $realtime;
m_after.push_back(delay);
endfunction
function void build_phase( uvm_phase phase );
before_export = new("before_export", this);
after_export = new("after_export", this);
endfunction
// Perform. calculation for longest delay metric
function void extract_phase( uvm_phase phase );
foreach (m_before[i])
if (m_before[i] > longest_b_delay) longest_b_delay = m_before[i];
foreach (m_after[i])
if (m_after[i] > longest_a_delay) longest_a_delay = m_after[i];
endfunction
function void check_phase( uvm_phase phase );
string s;
if (longest_a_delay > 100.0) begin
$sformat(s, "Transaction delay too long: %5.2f",longest_a_delay);
uvm_report_warning("Delay Analyzer",s);
end
if (longest_b_delay > 100.0) begin
end
endfunction
function void report_phase( uvm_phase phase );
uvm_report_info("Delay Analyzer", $sformatf("Longest BEFORE delay: %5.2f", longest_b_delay));
uvm_report_info("Delay Analyzer", $sformatf("Longest AFTER delay: %5.2f", longest_a_delay));
endfunction
endclass
(在http://verificationacademy.com/uvm-ovm上在线下载源代码示例)。
