Connecting the testbench to the DUT
【此处需一幅图】
在wishbone包装器中,为基类driver创建派生的concrete class driver的实例重载。请注意,此示例中的代码设置为处理wishbone总线包装器的多个实例(因此还有多个DUT),这是使用WB_ID参数来统一实例重载的原因。此参数在top_mac模块中设置。
module top_mac;
wb_bus_wrapper #(0) wb_bus_0();
endmodule
module wb_bus_wrapper #(int WB_ID = 0);
// Concrete driver class
class wb_bus_bfm_driver_c #(int ID = WB_ID) extends wb_bus_bfm_driver_base;
endclass
initial begin
//set inst override of concrete bfm driver for base bfm driver
wb_bus_bfm_driver_base::type_id::set_inst_override(
wb_bus_bfm_driver_c #(WB_ID)::get_type(),
$sformatf("*env_%0d*", WB_ID));
end
endmodule
【此处需一幅图】
在testbench中的wishbone agent中,声明了一个基类driver句柄。当它由factory创建时,重载将生效,并且将创建派生的concrete class driver object。作为此object的Verilog域来说,此对象包含的wishbone总线包装器及其Verilog路径将指示它位于top_mac(wb_bus_0)内部创建的wishbone总线包装器实例内。从UVM的角度来看,该对象是wishbone agent的UVM分层子代(不是子类,仅仅是agent包含了此object),其ports连接到wishbone agent中的ports。
class wb_master_agent extends uvm_agent;
//ports
uvm_analysis_port #(wb_txn) wb_agent_drv_ap;
// components
wb_bus_bfm_driver_base wb_drv;
wb_config m_config;
function void build_phase(uvm_phase phase);
super.build_phase(phase);
if (!uvm_config_db #(wb_config)::get(this, "", "wb_config", m_config)) // get config object
`uvm_fatal("Config Fatal", "Can't get the wb_config")
//ports
wb_agent_drv_ap = new("wb_agent_drv_ap", this);
//components
wb_drv = wb_bus_bfm_driver_base::type_id::create("wb_drv", this); // driver
endfunction : build_phase
function void connect_phase(uvm_phase phase);
super.connect_phase(phase);
//analysis ports
wb_drv.wb_drv_ap.connect(wb_agent_drv_ap);
// child ports
wb_drv.seq_item_port.connect(wb_seqr.seq_item_export);
endfunction : connect_phase
function void end_of_elaboration_phase(uvm_phase phase);
wb_drv.m_id = m_config.m_wb_master_id;
endfunction : end_of_elaboration_phase
endclass
(在http://verificationacademy.com/uvm-ovm上在线下载源代码示例)。
