Connections to DUT Interfaces(从Connect/TwoKingdomsFactory开始)
上一篇 / 下一篇  2018-09-27 16:52:39
      Abstract/base Class
       Abstract / base类被定义为测试平台中agent的一部分。在此示例中,它是基类driver,包括用于连接到wishbone总线agent的其余部分的端口。
       Wrapper module
       创建包装器模块,其包括BFM和DUT的实例。concrete类在模块内定义,因此其域将是包装器模块。
       在包装器模块内部创建concrete类的实例。使用uvm_container将此实例的句柄放在配置数据库中。
       【此处需一幅图】
       以下是WISHBONE总线BFM的代码。
       module wishbone_bus_syscon_bfm #(int num_masters = 8, int num_slaves = 8,
        int data_width = 32, int addr_width = 32) ();
              // WISHBONE signals
              bit clk;
              bit rst;
              // WISHBONE bus arbitration logic
              //Slave address decode
              // BFM tasks
              //WRITE 1 or more write cycles
              task wb_write_cycle(wb_txn req_txn, bit [2:0] m_id = 1);
              endtask
              //READ 1 or more cycles
              task wb_read_cycle(wb_txn req_txn, bit [2:0] m_id = 1, output wb_txn rsp_txn);
              endtask
              // Monitor bus transactions
              task monitor(output wb_txn txn);
              endtask
       endmodule
       下面是WISHBONE总线包装模块的代码。注意BFM(wishbone_bus_syscon_bfm)、slave memory(wb_slave_mem)和以太网MAC(eth_top)的实例。除了未示出或讨论的WISHBONE接口之外,MAC芯片还具有媒体独立接口(MII)。实际上,在此总线包装器中定义了两个concrete类 - driver和monitor,但仅显示和讨论了driver(wb_bus_bfm_driver_c)。
        module wb_bus_wrapper #(int WB_ID = 0);
               // WISHBONE BFM instance
               // Supports up to 8 masters and up to 8 slaves
               wishbone_bus_syscon_bfm wb_bfm();
               // WISHBONE 0, slave 0: 000000 - 0fffff
               wb_slave_mem #(mem_slave_size) wb_s_0 ( ... );
               // MAC 0
               // It is WISHBONE slave 1: address range 100000 - 100fff
               // It is WISHBONE Master 0
               eth_top mac_0 ( ... );
               // Concrete driver class
               class wb_bus_bfm_driver_c #(int ID = WB_ID) extends wb_bus_bfm_driver_base;
               endclass
        endmodule
        例如,如果concrete driver class接收到WISHBONE写入事务,则它调用其本地wb_write_cycle() task,该 task又调用BFM内的wb_write_cycle() task。
                    task run_phase(uvm_phase phase);
                         wb_txn req_txn;
                         forever begin
                             seq_item_port.get(req_txn); // get transaction
                             @ ( posedge wb_bfm.clk) #1; // sync to clock edge + 1 time step
                             case(req_txn.txn_type) //what type of transaction?
                                   NONE: `uvm_info($sformatf("WB_M_DRVR_%0d",m_id),
        $sformatf("wb_txn %0d the wb_txn_type was type       NONE",req_txn.get_transaction_id()),UVM_LOW )
                                  WRITE: wb_write_cycle(req_txn);
                                  READ: wb_read_cycle(req_txn);
                                  RMW: wb_rmw_cycle(req_txn);
                                  WAIT_IRQ: fork wb_irq(req_txn); join_none
                                  default: `uvm_error($sformatf("WB_M_DRVR_%0d",m_id),
        $sformatf("wb_txn %0d the wb_txn_type was type illegal",req_txn.get_transaction_id()) )
                             endcase
                         end
                    endtask : run_phase
                    // Methods
                    // calls corresponding BFM methods
                    task wb_write_cycle(wb_txn req_txn);
                         wb_txn orig_req_txn;
                         $cast(orig_req_txn, req_txn.clone()); //save off copy of original req transaction
                         wb_bfm.wb_write_cycle(req_txn, m_id);
                         wb_drv_ap.write(orig_req_txn); //broadcast orignal transaction
                     endtask
               endclass
        endmodule
TAG:
评分:0
我来说两句
显示全部
日历
« 2019-01-17
  12345
6789101112
13141516171819
20212223242526
2728293031
数据统计
  • 访问量: 19732
  • 日志数: 75
  • 建立时间: 2018-09-03
  • 更新时间: 2018-12-29
RSS订阅
Open Toolbar
