The Test
与块级test一样,集成级test应该具有在后续test case中可以继承的基类中可以使用的公共build和configuration过程。从示例中可以看出,还有更多配置要做,因此这种配置需求变得更加引人关注。
pss_env的配置对象包含spi_env和gpio_env的配置对象的句柄。依次地,子env配置对象包含其agent子组件配置对象的句柄。pss_env负责解嵌套spi_env和gpio_env配置对象并在其配置表中进行设置,因此进行一些局部更改是有必要的。依次地,spi_env和gpio_env将其agent配置放入其配置表中。
pss测试基类如下:
// Class Description:
class pss_test_base extends uvm_test;
// UVM Factory Registration Macro
`uvm_component_utils(pss_test_base)
// Data Members
// Component Members
// The environment class
pss_env m_env;
// Configuration objects
pss_env_config m_env_cfg;
spi_env_config m_spi_env_cfg;
gpio_env_config m_gpio_env_cfg;
//uart_env_config m_uart_env_cfg;
apb_agent_config m_spi_apb_agent_cfg;
apb_agent_config m_gpio_apb_agent_cfg;
ahb_agent_config m_ahb_agent_cfg;
spi_agent_config m_spi_agent_cfg;
gpio_agent_config m_GPO_agent_cfg;
gpio_agent_config m_GPI_agent_cfg;
gpio_agent_config m_GPOE_agent_cfg;
// Register map
pss_register_map pss_rm;
// Methods
// Standard UVM Methods:
extern function new(string name = "spi_test_base", uvm_component parent = null);
extern function void build_phase( uvm_phase phase);
extern virtual function void configure_apb_agent(apb_agent_config cfg, int index, logic[31:0] start_address, logic[31:0] range);
extern task run_phase( uvm_phase phase );
endclass: pss_test_base
function pss_test_base::new(string name = "spi_test_base", uvm_component parent = null);
super.new(name, parent);
endfunction
// Build the env, create the env configuration
// including any sub configurations and assigning virtural interfaces
function void pss_test_base::build_phase( uvm_phase );
m_env_cfg = pss_env_config::type_id::create("m_env_cfg");
// Register map - Keep reg_map a generic name for vertical reuse reasons
pss_rm = new("reg_map", null);
m_env_cfg.pss_rm = pss_rm;
// SPI Sub-env configuration:
m_spi_env_cfg = spi_env_config::type_id::create("m_spi_env_cfg");
m_spi_env_cfg.spi_rm = pss_rm;
// apb agent in the SPI env:
m_spi_env_cfg.has_apb_agent = 1;
m_spi_apb_agent_cfg = apb_agent_config::type_id::create("m_spi_apb_agent_cfg");
configure_apb_agent(m_spi_apb_agent_cfg, 0, 32'h0, 32'h18);
if( !uvm_config_db #(virtual apb_if)::get(this, "","APB_vif",m_spi_apb_agent_cfg.APB) ) `uvm_error(...)
m_spi_env_cfg.m_apb_agent_cfg = m_spi_apb_agent_cfg;
// SPI agent:
m_spi_agent_cfg = spi_agent_config::type_id::create("m_spi_agent_cfg");
if( !uvm_config_db #(virtual spi_if)::get(this, "" , "SPI_vif",m_spi_agent_cfg.SPI) ) `uvm_error(...)
m_spi_env_cfg.m_spi_agent_cfg = m_spi_agent_cfg;
m_env_cfg.m_spi_env_cfg = m_spi_env_cfg;
if( !uvm_config_db #( spi_env_config )::set("*", "", "spi_env_config", m_spi_env_cfg) ) `uvm_error(...)
// GPIO env configuration:
m_gpio_env_cfg = gpio_env_config::type_id::create("m_gpio_env_cfg");
m_gpio_env_cfg.gpio_rm = pss_rm;
m_gpio_env_cfg.has_apb_agent = 1; // APB agent used
m_gpio_apb_agent_cfg = apb_agent_config::type_id::create("m_gpio_apb_agent_cfg");
configure_apb_agent(m_gpio_apb_agent_cfg, 1, 32'h100, 32'h124);
if( !uvm_config_db #(virtual apb_if)::get(this, "" , "APB_vif",m_gpio_apb_agent_cfg.APB) ) `uvm_error(...)
m_gpio_env_cfg.m_apb_agent_cfg = m_gpio_apb_agent_cfg;
m_gpio_env_cfg.has_functional_coverage = 1; // Register coverage no longer valid
// GPO agent
m_GPO_agent_cfg = gpio_agent_config::type_id::create("m_GPO_agent_cfg");
uvm_config_db #(virtual gpio_if)::get(this, "GPO_vif",m_GPO_agent_cfg.GPIO);
m_GPO_agent_cfg.active = UVM_PASSIVE; // Only monitors
m_gpio_env_cfg.m_GPO_agent_cfg = m_GPO_agent_cfg;
// GPOE agent
m_GPOE_agent_cfg = gpio_agent_config::type_id::create("m_GPOE_agent_cfg");
uvm_config_db #(virtual gpio_if)::get(this, "GPOE_vif",m_GPOE_agent_cfg.GPIO);
m_GPOE_agent_cfg.active = UVM_PASSIVE; // Only monitors
m_gpio_env_cfg.m_GPOE_agent_cfg = m_GPOE_agent_cfg;
// GPI agent - active (default)
m_GPI_agent_cfg = gpio_agent_config::type_id::create("m_GPI_agent_cfg");
if( !uvm_config_db #(virtual gpio_if)::get(this, "" , "GPI_vif",m_GPI_agent_cfg.GPIO) ) `uvm_error(...)
m_gpio_env_cfg.m_GPI_agent_cfg = m_GPI_agent_cfg;
// GPIO Aux agent not present
m_gpio_env_cfg.has_AUX_agent = 0;
m_gpio_env_cfg.has_reg_scoreboard = 0;
m_gpio_env_cfg.has_out_scoreboard = 1;
m_gpio_env_cfg.has_in_scoreboard = 1;
m_env_cfg.m_gpio_env_cfg = m_gpio_env_cfg;
uvm_config_db #( gpio_env_config )::set( this , "*", "gpio_env_config", m_gpio_env_cfg);
// AHB Agent
m_ahb_agent_cfg = ahb_agent_config::type_id::create("m_ahb_agent_cfg");
if( !uvm_config_db #(virtual ahb_if)::get(this, "", "AHB_vif",m_ahb_agent_cfg.AHB) ) `uvm_error(...)
m_env_cfg.m_ahb_agent_cfg = m_ahb_agent_cfg;
// Add in interrupt line
if( !uvm_config_db #(virtual icpit_if)::get(this, "", "ICPIT_vif",m_env_cfg.ICPIT) ) `uvm_error(...)
uvm_config_db::set( this , "*", "pss_env_config", m_env_cfg);
m_env = pss_env::type_id::create("m_env", this);
// Override for register adapters:
register_adapter_base::type_id::set_inst_override(ahb_register_adapter::get_type(), "spi_bus.adapter");
register_adapter_base::type_id::set_inst_override(ahb_register_adapter::get_type(), "gpio_bus.adapter");
endfunction: build_phase
// Convenience function to configure the apb agent
// This can be overloaded by extensions to this base class
function void pss_test_base::configure_apb_agent(apb_agent_config cfg, int index, logic[31:0] start_address, logic[31:0] range);
cfg.has_functional_coverage = 0;
cfg.has_scoreboard = 0;
cfg.no_select_lines = 1;
cfg.apb_index = index;
cfg.start_address[0] = start_address;
cfg.range[0] = range;
endfunction: configure_apb_agent
task pss_test_base::run_phase( uvm_phase phase );
endtask: run_phase
同样,扩展此基类的测试用例将对其run方法进行扩展填充,以定义将在env中的virtual sequencer上运行的virtual sequence。如果要进行非默认的配置,则可以通过扩展填充或重载build方法或一些配置方法来完成。
class pss_test extends pss_test_base;
`uvm_component_utils(pss_test)
// Methods
extern function new(string name = "pss_test", uvm_component parent = null);
extern function void build_phase( ovm_phase phase);
endclass: pss_test
function pss_test::new(string name = "pss_test", uvm_component parent = null);
endfunction
// including any sub configurations and assigning virtual interfaces
function void pss_test::build_phase( uvm_phase phase);
super.build_phase( uvm_phase phase );
// Create, initialise and then run the virtual sequence
task pss_test::run_phase( uvm_phase phase );
bridge_basic_rw_vseq t_seq = bridge_basic_rw_vseq::type_id::create("t_seq");
phase.raise_objection( this , "Starting PSS test");
init_vseq(t_seq);
repeat(10) begin
t_seq.start(null);
end
phase.drop_objection( this , "Finished PSS test");
endtask: run_phase
