kakaiki的个人空间 https://blog.eetop.cn/1038751 [收藏] [复制] [分享] [RSS]
PSCAD Professional 5.0.1 Update 1 x64 with Full License
已有 164 次阅读| 2024-5-14 19:56 |系统分类:芯片设计
PSCAD is one of the specialized software in the field of electrical engineering, which is used to analyze and simulate power circuits and receive responses in various transient and stable states.   In this software, circuits can be schematically designed, simulated and implemented and can the answers be analyzed.   This software has a library of pre-designed and tested models that include simple passive elements, complex controllers, electric machines, devices and transmission lines and cables.   The information in this software is presented in a completely graphical environment and you can draw graphs and measure system variables at the same time.   In this software, the user finds the possibility to redesign
PRSIM™ (Power System Importer) - Included in Enhanced Package The PRSIM application is available in the enhanced package and allows users to convert standard PSSE or PowerFactory network data to PSCAD with minimal time and effort.
  • Convert PSS/E and PowerFactory data files to PSCAD V5.0 and V4.6
  • Import detailed dynamic data
  • Import sequence data
  • Import location data for automatic schematic expansion
  • Form network equivalents for unexpanded segments of the network
  • Re-initialize previously generated PSCAD projects
PSCAD Initializer
An Electro Magnetic Transient (EMT) program such as PSCAD simulates the behavior of a power system network after a disturbance, such as a fault or a circuit breaker operation. During this short period, the system gradually changes from one steady-state behavior to another .
The purpose of the PSCAD Initializer is to set up the proper power flow conditions (eg correct voltage and angles at buses, active, reactive power flows between buses, etc.) prior to the disturbance. This involves a solution to the power flow equations and setting up the correct parameters of generators, sources in PSCAD, etc.
other features include:
  • Automation: Embedded Python Scripting With Recording
  • Modified, Augmented Nodal Analysis (MANA) in EMTDC
  • KLU Sparsity Algorithm in EMTDC
  • New Master Library Models
  • General Master Library Model Enhancements
  • Blackbox Upgrade
  • New and Improved External Resource File Handling
  • New Binary EMTDC Output File Format
  • Co-Simulation Interface
  • Rubber Banding (Sticky Wires)
  • Cluster Launch System (CLS)
  • Tandem Lines: Sliding Faults
  • Mixing of Overhead and Underground Transmission Systems
  • COMPLEX Signal Type
  • Enhanced Component Parameter Dialog
  • Project Navigation Enhancements
  • Improved Parallel Multiple Run (PMR)
  • New and Enhanced Global Substitutions Design
  • New and Improved Parameter Grid
  • Smart Paste
If you are interested in the full licensed software PSCAD Professional 5.0.1 Update 1   with full feature license and tutorial examples, then do well to contact  kefu007@vip.qq.com
PLEASE NOTE
Also, if you are interested in other EDA software like: EMPIRE XPU 8.1.3 , Remcom XFDTD 7.10.1, Remcom XGTD 3.1.2, Remcom Wireless Insite 3.3.5, Remcom WaveFarer Radar Software 2.1, Sonnet Suite Pro 18.56 and ASN Filter Designer 5.2.1, Tetcos Netsim Professional 13.1, DigacSilent 2022, VPI Photonic TransmissionMaker 11.1, Optenni Lab 5.0, EMTP-RV 4.2.1, SpiceVision 7.0 and StarVision etc. please contact kefu007@vip.qq.com
全部作者的其他最新日志
  • 1
  • 4
GMT+8, 2024-5-31 10:16 , Processed in 0.031963 second(s), 14 queries , Gzip On, Redis On.
