大家好,我是国芯网-站长,很高兴在这里安家,希望交更多半导体行业的朋友,祝大家快乐!
双路 3.3 MHz 低功耗 CMOS,EMI 硬化运算放大器LMV832/834替换
上一篇 / 下一篇  2017-11-07 09:39:13
描述
TI’s LMV83x devices are CMOS input, low-power operation amplifier ICs, providing a low input bias current, a wide temperature range of –40°C to 125°C, and exceptional performance, making them robust general-purpose parts. Additionally, the LMV83x are EMI-hardened to minimize any interference, making them ideal for EMI-sensitive applications.
The unity gain stable LMV83x feature 3.3-MHz of bandwidth while consuming only 0.24 mA of current per channel. These parts also maintain stability for capacitive loads as large as 200 pF. The LMV83x provide superior performance and economy in terms of power and space usage.
This family of parts has a maximum input offset voltage of 1 mV, a rail-to-rail output stage and an input common-mode voltage range that includes ground. Over an operating range from 2.7 V to 5.5 V, the LMV83x provide a PSRR of 93 dB, and a CMRR of 91 dB. The LMV831 is offered in the space-saving 5-pin SC70 package, the LMV832 in the 8-pin VSSOP and the LMV834 is offered in the 14--in TSSOP package.
特性
Unless Otherwise Noted, Typical Values at
TA= 25°C, V+ = 3.3 V
Supply Voltage 2.7 V to 5.5 V
Supply Current (per Channel) 240 μA
Input Offset Voltage 1-mV Maximum
Input Bias Current 0.1 pA
GBW 3.3 MHz
EMIRR at 1.8 GHz 120 dB
Input Noise Voltage at 1 kHz 12 nV/√Hz
Slew Rate 2 V/μs
Output Voltage Swing Rail-to-Rail
Output Current Drive 30 mA
Operating Ambient Temperature Range –40°C to
125°C
中广芯源专业电源方案,运算放大器,马达驱动,大功率MOS 等系统服务商,小家电电源方案,工业辅助电源方案,智能LED调光电源驱动IC,功率:30W以内,有针对性的方案提供产品特色降低系统成本,提高设计灵活性。
1 220V降压12V/24V输出功率更大以适应更高功率的应用
2 非隔离电路无需变压器,外围电路更简单
3 节约外围元件成本
4 完全集成的缓启动电路降低了器件的应力及输出电压过冲
5 外部电路实现精确的限流编程
6 更宽的占空比实现更高的输出功率,同时可以使用更小尺寸的输入滤波电容
7 输入欠压(UV)检测可以防止关机时输出的不良波动
8 输入过压(OV)关断电路提高了对输入浪涌的耐受力
9 具有输出短路保护,开路保护功能
MC34119 小功率音频放大器
NE592 视频放大器OP07-CP精密运算放大器 TI[DATA] OP07-DP 精密运算放大器 TI[
NE5532 高速低噪声双运算放大器 TI   双运放 NE5534 高速低噪声单运算放大器 TI   单运放 OPA602  高速高精度运放(无OPA2602) OPA604单  OPA2604双   低噪声运放
OPA132单  OPA2132双  OPA4132四  高速低噪运放
OPA227 OPA2227 OPA4227  OPA228 OPA2228 OPA4228 高精度低噪声运放
AD844:60MHz、2000V/us单芯片运算放大器 高带宽、非常快速的大信号响应特性
常用的压控放大器:AD603  VCA810  VCA820 AD603:低噪声 电压控制增益运放 90MHz带宽 VCA810:35MHz高增益可调节范围宽带压控放大器
25mV/dB(-40dB~40dB)
VCA820:150MHz增益可调运放(-20~+20dB)
OK358   带宽1MHZ双运放
OK321 324  带宽1MHZ 四通道运放
OK522  带宽3.6MHZ   低噪声双运放
OK722  带宽 10MHZ  低噪声双运放
OK121 122  222低静态功耗 单通道和双通道运放
OK222  224 带宽250MHZ 高速运放 单双通道
OK8551  8552 8554高精密 零温漂 单通道 双通道运放
高精度带宽 4.5M 运算放大器 AD8551(单通道),AD8552(双通道),AD8554(四通道)
应用领域:
温度测量
压力传感器
精密电流传感
电子秤
应变计放大器
医疗仪器
热电偶放大器
手持式测试设备
替代兼容产品:
圣邦微电子: SGM8551,SGM8552,SGM8554,SGM8581,SGM8582,SGM8584
ADI:         AD8551,AD8552,AD8554
3PEAK(思瑞浦):TP5551,TP5552,TP5554,TP5591,TP5592,TP5594
中广芯源
姜楠    手机:134 2429 7678   QQ:1004509729     邮箱:mk008@zgsemi.com
罗生    手机:134 2514 6336   QQ: 2805981750     邮箱:mk003@zgsemi.com
梁女士  手机:183 1938 1531   QQ: 2671598306     邮箱:mk99@zgsemi.com
杨女士  手机:136 3252 9254   QQ: 2466385476    邮箱:mk015@zgsemi.com
刘女士  手机:150 1404 3136   QQ: 1748986374     邮箱:mk006@zgsemi.com
商务    手机:138 2657 2159   QQ: 2573705058     邮箱:mk009@zgsemi.com
公司电话:0755-29469758
公司旗下网站:http://www.086ic.cn
公司企业网址:http://www.zgsemi.com  http://www.nxppower.com
TAG: MHz 低功耗 双路
评分:0
我来说两句
显示全部
日历
« 2019-01-09
  12345
6789101112
13141516171819
20212223242526
2728293031
数据统计
  • 访问量: 267440
  • 日志数: 360
  • 建立时间: 2010-09-18
  • 更新时间: 2018-12-08
RSS订阅
Open Toolbar
