描述
The LMV721 (single) and LMV722 (dual) are low-noise low-voltage low-power operational amplifiers that can be designed into a wide range of applications. The LMV721 and LMV722 have a unity-gain bandwidth of 10 MHz, a slew rate of 5 V/μs, and a quiescent current of 930 μA/amplifier at 2.2 V.
The LMV721 and LMV722 are designed to provide optimal performance in low-voltage and low-noise systems. They provide rail-to-rail output swing into heavy loads. The input common-mode voltage range includes ground, and the maximum input offset voltage are 3.5 mV (over recommended temperature range) for the devices. Their capacitive load capability is also good at low supply voltages. The operating range is from 2.2 V to 5.5 V.
特性
Power-Supply Voltage Range: 2.2 V to 5.5 V
Low Supply Current: 930 μA/Amplifier at 2.2 V
High Unity-Gain Bandwidth: 10 MHz
Rail-to-Rail Output Swing
600- Load: 120 mV From Either Rail at 2.2 V
2-k Load: 50 mV From Either Rail at 2.2 V
Input Common-Mode Voltage Range Includes Ground
Input Voltage Noise: 9 nV/√Hz at f = 1 kHz
APPLICATIONS
Cellular and Cordless Phones
Active Filter and Buffers
Laptops and PDAs
Battery Powered Electronics
中广芯源专业电源方案,运算放大器,马达驱动,大功率MOS 等系统服务商,小家电电源方案,工业辅助电源方案,智能LED调光电源驱动IC,功率:30W以内,有针对性的方案提供产品特色降低系统成本,提高设计灵活性。
1 220V降压12V/24V输出功率更大以适应更高功率的应用
2 非隔离电路无需变压器,外围电路更简单
3 节约外围元件成本
4 完全集成的缓启动电路降低了器件的应力及输出电压过冲
5 外部电路实现精确的限流编程
6 更宽的占空比实现更高的输出功率,同时可以使用更小尺寸的输入滤波电容
7 输入欠压(UV)检测可以防止关机时输出的不良波动
8 输入过压(OV)关断电路提高了对输入浪涌的耐受力
9 具有输出短路保护,开路保护功能
MC34119 小功率音频放大器
NE592 视频放大器OP07-CP精密运算放大器 TI[DATA] OP07-DP 精密运算放大器 TI[
NE5532 高速低噪声双运算放大器 TI 双运放 NE5534 高速低噪声单运算放大器 TI 单运放 OPA602 高速高精度运放(无OPA2602) OPA604单 OPA2604双 低噪声运放
OPA132单 OPA2132双 OPA4132四 高速低噪运放
OPA227 OPA2227 OPA4227 OPA228 OPA2228 OPA4228 高精度低噪声运放
AD844:60MHz、2000V/us单芯片运算放大器 高带宽、非常快速的大信号响应特性
常用的压控放大器:AD603 VCA810 VCA820 AD603:低噪声 电压控制增益运放 90MHz带宽 VCA810:35MHz高增益可调节范围宽带压控放大器
25mV/dB(-40dB~40dB)
VCA820:150MHz增益可调运放(-20~+20dB)
OK358 带宽1MHZ双运放
OK321 324 带宽1MHZ 四通道运放
OK522 带宽3.6MHZ 低噪声双运放
OK722 带宽 10MHZ 低噪声双运放
OK121 122 222低静态功耗 单通道和双通道运放
OK222 224 带宽250MHZ 高速运放 单双通道
OK8551 8552 8554高精密 零温漂 单通道 双通道运放
高精度带宽 4.5M 运算放大器 AD8551(单通道),AD8552(双通道),AD8554(四通道)
应用领域:
温度测量
压力传感器
精密电流传感
电子秤
应变计放大器
医疗仪器
热电偶放大器
手持式测试设备
替代兼容产品:
圣邦微电子: SGM8551,SGM8552,SGM8554,SGM8581,SGM8582,SGM8584
ADI: AD8551,AD8552,AD8554
3PEAK(思瑞浦):TP5551,TP5552,TP5554,TP5591,TP5592,TP5594
中广芯源
姜楠 手机:134 2429 7678 QQ:1004509729 邮箱:mk008@zgsemi.com
罗生 手机:134 2514 6336 QQ: 2805981750 邮箱:mk003@zgsemi.com
梁女士 手机:183 1938 1531 QQ: 2671598306 邮箱:mk99@zgsemi.com
杨女士 手机:136 3252 9254 QQ: 2466385476 邮箱:mk015@zgsemi.com
刘女士 手机:150 1404 3136 QQ: 1748986374 邮箱:mk006@zgsemi.com
商务 手机:138 2657 2159 QQ: 2573705058 邮箱:mk009@zgsemi.com
公司电话:0755-29469758
公司旗下网站:http://www.086ic.cn
公司企业网址:http://www.zgsemi.com http://www.nxppower.com
