描述
The LMH6601 device is a low-voltage (2.4 V to 5.5 V), high-speed voltage feedback operational amplifier suitable for use in a variety of consumer and industrial applications. With a bandwidth of 125 MHz at a gain of +2 and ensured high-output current of 100 mA, the LMH6601 is an ideal choice for video line driver applications, including HDTV. Low-input bias current (50 pA maximum), rail-to-rail output, and low current noise allow the use of the LMH6601 in various industrial applications such as transimpedance amplifiers, active filters, or high-impedance buffers. The LMH6601 is an attractive solution for systems which require high performance at low supply voltages. The LMH6601 is available in a 6-pin SC70 package, and includes a micropower shutdown feature.
特性
LMH6601-Q1 Qualified for Automotive Applications
AEC-Q100 Grade 3
–40°C to 85°C Ambient Operating
Temperature Range
VS = 3.3 V, TA = 25°C,
AV = 2 V/V, RL = 150 Ω to
V–, Unless Specified
125 MHz –3 dB Small Signal Bandwidth
75 MHz –3 dB Large Signal Bandwidth
30 MHz Large Signal 0.1-dB Gain Flatness
260 V/μs Slew Rate
0.25%/0.25° Differential Gain and Differential
Phase
Rail-to-Rail Output
2.4-V to 5.5-V Single-Supply Operating Range
6-Pin SC70 Package
中广芯源专业电源方案系统服务商,小家电电源方案,工业辅助电源方案,智
能LED调光电源驱动IC,功率:30W以内,有针对性的方案提供产品特色降低系统
成本,提高设计灵活性。
1 220V降压12V/24V输出功率更大以适应更高功率的应用
2 非隔离电路无需变压器,外围电路更简单
3 节约外围元件成本
4 完全集成的缓启动电路降低了器件的应力及输出电压过冲
5 外部电路实现精确的限流编程
6 更宽的占空比实现更高的输出功率,同时可以使用更小尺寸的输入滤波电容
7 输入欠压(UV)检测可以防止关机时输出的不良波动
8 输入过压(OV)关断电路提高了对输入浪涌的耐受力
9 具有输出短路保护,开路保护功能
高精度带宽 4.5M 运算放大器 AD8551(单通道),AD8552(双通道),AD8554
(四通道)
应用领域:
温度测量
压力传感器
精密电流传感
电子秤
应变计放大器
医疗仪器
热电偶放大器
手持式测试设备
替代兼容产品:
圣邦微电子: SGM8551,SGM8552,SGM8554,SGM8581,SGM8582,SGM8584
ADI: AD8551,AD8552,AD8554
3PEAK(思瑞浦):TP5551,TP5552,TP5554,TP5591,TP5592,TP5594
中广芯源
姜楠 手机:134 2429 7678 QQ:1004509729 邮箱:
mk008@zgsemi.com
罗生 手机:134 2514 6336 QQ: 2805981750 邮箱:
mk003@zgsemi.com
梁女士 手机:183 1938 1531 QQ: 2671598306 邮箱:
mk99@zgsemi.com
杨女士 手机:136 3252 9254 QQ: 2466385476 邮箱:
mk015@zgsemi.com
刘女士 手机:150 1404 3136 QQ: 1748986374 邮箱:
mk006@zgsemi.com
商务 手机:138 2657 2159 QQ: 2573705058 邮箱:
mk009@zgsemi.com
公司电话:0755-29469758
公司旗下网站:http://www.086ic.cn
公司企业网址:http://www.zgsemi.com http://www.nxppower.com
