http://www.cnblogs.com/yoran/archive/2008/02/28/1085316.html
二分查找的代码.
int bfind(int* a,int len,int val)
int m = len/2;
int l = 0;
int r = len;
while(l!=m && r!= m)
if(a[m] > val)
r = m;
m = (m+l)/2;
else if(a[m] < val)
l = m;
m = (m+r)/2;
else
return m;
return -1; //没有找到
写出在母串中查找子串出现次数的代码.
int count1(char* str,char* s)
char* s1;
char* s2;
int count = 0;
while(*str!='\0')
s1 = str;
s2 = s;
while(*s2 == *s1&&(*s2!='\0')&&(*s1!='0'))
s2++;
s1++;
if(*s2 == '\0')
count++;
str++;
return count;
查找第一个匹配子串位置,如果返回的是s1长度len1表示没有找到
size_t find(char* s1,char* s2)
size_t i=0;
size_t len1 = strlen(s1)
size_t len2 = strlen(s2);
if(len1-len2<0) return len1;
for(;i {
size_t m = i;
for(size_t j=0;j {
if(s1[m]!=s2[j])
break;
m++;
if(j==len)
break;
return i }
写出快速排序或者某种排序算法代码
快速排序:
int partition(int* a,int l,int r)
int i=l-1,j=r,v=a[r];
while(1)
while(a[++i] while(a[--j]>v) if(j<=i) break;
if(i>=j)
break;
swap(a[i],a[j]);
swap(a[i],a[r]);
return i;
void qsort(int* a,int l,int r)
if(l>=r) return;
int i = partition(a,l,r);
qsort(a,l,i-1);
qsort(a,i+1,r);
冒泡排序:
void buble(int *a,int n)
for(int i=0;i {
for(int j=1;j {
if(a[j] {
int temp=a[j];
a[j] = a[j-1];
a[j-1] = temp;
插入排序:
void insertsort(int* a,int n)
int key;
for(int j=1;j {
key = a[j];
for(int i=j-1;i>=0&&a[i]>key;i--)
a[i+1] = a[i];
a[i+1] = key;
出现次数相当频繁
实现strcmp函数
int strcmp11(char* l,char* r)
assert(l!=0&&r!=0);
while(*l == *r &&*l != '\0') l++,r++;
if(*l > *r)
return 1;
else if(*l == *r)
return 0;
return -1;
实现字符串翻转
void reserve(char* str)
assert(str != NULL);
char * p1 = str;
char * p2 = str-1;
while(*++p2); //一般要求不能使用strlen
p2 -= 1;
while(p1 {
char c = *p1;
*p1++ = *p2;
*p2-- = c;
将一个单链表逆序
struct list_node
list_node(int a,list_node* b):data(a),next(b) //这个为了测试方便
int data;
list_node* next;
void reserve(list_node* phead)
list_node* p = phead->next;
if(p == NULL || p->next == NULL) return; //只有头节点或一个节点
list_node* p1=p->next;
p->next=NULL;
while(p1!=NULL)
p = p1->next;
p1->next = phead->next;
phead->next = p1;
p1 = p;
测试程序:
list lt;
lt.phead = new list_node(0,0);
lt.phead->next = new list_node(1,0);
lt.phead->next->next = new list_node(2,0);
lt.phead->next->next->next = new list_node(3,0);
lt.reserve();
list_node * p = lt.phead;
while(p)
cout<data< p = p->next;
循环链表的节点对换和删除。
//双向循环
list_node* earse(list_node* node)
// if(node == rear) return node->next; //对于头节点可判断也可不判断。最好加上
list_node* next = node->next;
next->prev = node->prev;
node->prev->next = next;
delete node;
retrun next;
//单项循环
list_node* p = rear;
while(p->next != node) p=p->next;
p->next = node->next;
delete node;
retrun p->next;
将一个数字字符串转换为数字."1234" -->1234
int atoii(char* s)
assert(s!=NULL);
int num = 0;
int temp;
while(*s>'0' && *s<'9')
num *= 10;
num += *s-'0';
s++;
return num;
出现次数相当频繁
.实现任意长度的整数相加或者相乘功能。
void bigadd(char* num,char* str,int len)
for(int i=len;i>0;i--)
num[i] += str[i];
int j = i;
while(num[j]>=10)
num[j--] -= 10;
num[j] += 1;
.写函数完成内存的拷贝
void* memcpy( void *dst, const void *src, unsigned int len )
register char *d;
register char *s;
if (len == 0)
return dst;
if ( dst > src ) //考虑覆盖情况
d = (char *)dst + len - 1;
s = (char *)src + len - 1;
while ( len >= 4 ) //循环展开,提高执行效率
*d-- = *s--;
*d-- = *s--;
*d-- = *s--;
*d-- = *s--;
len -= 4;
while ( len-- )
*d-- = *s--;
else if ( dst < src )
d = (char *)dst;
s = (char *)src;
while ( len >= 4 )
*d++ = *s++;
*d++ = *s++;
*d++ = *s++;
*d++ = *s++;
len -= 4;
while ( len-- )
*d++ = *s++;
return dst;
出现次数相当频繁
编写类String的构造函数、析构函数和赋值函数,已知类String的原型为:
class String
public:
String(const char *str = NULL); // 普通构造函数
String(const String &other); // 拷贝构造函数
~ String(void); // 析构函数
String & perate =(const String &other); // 赋值函数
private:
char *m_data; // 用于保存字符串
解答:
//普通构造函数
String::String(const char *str)
if(str==NULL)
m_data = new char[1]; // 得分点:对空字符串自动申请存放结束标志'\0'的空
//加分点:对m_data加NULL 判断
*m_data = '\0';
else
int length = strlen(str);
m_data = new char[length+1]; // 若能加 NULL 判断则更好
strcpy(m_data, str);
// String的析构函数
String::~String(void)
delete [] m_data; // 或delete m_data;
//拷贝构造函数
String::String(const String &other) // 得分点:输入参数为const型
int length = strlen(other.m_data);
m_data = new char[length+1]; //加分点:对m_data加NULL 判断
strcpy(m_data, other.m_data);
//赋值函数
String & String::operate =(const String &other) // 得分点:输入参数为const型
if(this == &other) //得分点:检查自赋值
return *this;
delete [] m_data; //得分点:释放原有的内存资源
int length = strlen( other.m_data );
strcpy( m_data, other.m_data );
return *this; //得分点:返回本对象的引用
剖析:
能够准确无误地编写出String类的构造函数、拷贝构造函数、赋值函数和析构函数的面试者至少已经具备了C++基本功的60%以上!
在这个类中包括了指针类成员变量m_data,当类中包括指针类成员变量时,一定要重载其拷贝构造函数、赋值函数和析构函数,这既是对C++程序员的基本要求,也是《Effective C++》中特别强调的条款。
实现strcpy
char * strcpy( char *strDest, const char *strSrc )
assert( (strDest != NULL) && (strSrc != NULL) );
char *address = strDest;
while( (*strDest++ = * strSrc++) != ‘\0’ );
return address;
编写一个函数,作用是把一个char组成的字符串循环右移n个。比如原来是“abcdefghi”如果n=2,移位后应该是“hiabcdefgh”
函数头是这样的:
//pStr是指向以'\0'结尾的字符串的指针
//steps是要求移动的n
void LoopMove ( char * pStr, int steps )
//请填充...
解答:
正确解答1:
void LoopMove ( char *pStr, int steps )
int n = strlen( pStr ) - steps;
char tmp[MAX_LEN];
strcpy ( tmp, pStr + n );
strcpy ( tmp + steps, pStr);
*( tmp + strlen ( pStr ) ) = '\0';
strcpy( pStr, tmp );
正确解答2:
char tmp[MAX_LEN];
memcpy( tmp, pStr + n, steps );
memcpy(pStr + steps, pStr, n );
memcpy(pStr, tmp, steps );
