MIPS应该说是我们最常见的衡量CPU速度的单位了,全称是Million Instructions Per Second,即每秒执行了多少百万条指令
DMIPS是我最近才去深入的一个单位,以前看到都不求甚解了,汗一下...
D是Dhrystone的缩写,他表示了在Dhrystone这样一种测试方法下的MIPS,Dhrystone是一种整数运算测试程序。下面是在FOLDOC上的解释:
Dhrystone
A short synthetic benchmark program by Reinhold Weicker weicker.muc@sni.de, weicker.muc@sni-usa.com, intended to be representative of system (integer) programming. It is available in ADA, Pascal and C.The current version is Dhrystone 2.1. The author says, "Relying on MIPS V1.1 (the result of V1.1) numbers can be hazardous to your professional health."
Due to its small size, the memory system outside the cache is not tested. Compilers can too easily optimise for Dhrystone. String operations are somewhat over-represented.
(2002-03-26)
(c) Copyright 1993 by Denis Howe
MFLOPS在FOLDOC上的解释如下:
A benchmark which attemps to estimate a system's floating-point "MFLOPS" rating for specific FADD, FSUB, FMUL and FDIV instruction mixes.
是一种基于浮点运算的CPU测试程序,当然,这种测试的结果也以 MFLOPS来加以表示,代表了CPU处理浮点运算的能力。
CPU性能评估采用综合测试程序,较流行的有Whetstone 和 Dhrystone 两种。Dhrystone主要用于测整数计算能力,计算单位就是DMIPS。采用Whetstone 主要用于测浮点计算能力,计算单位就是MFLOPS。
