linear-feedback-shift-register
下面是一个八位的伪随机数产生的verilog文件,我想够用了。
// DEFINES
`timescale 1ns/1ns
`define DEL 1 // Clock-to-output delay. Zero
// time delays can be confusing
// and sometimes cause problems.
// These are good tap values for 2 to 32 bits
`define TAP2 2'b11
`define TAP3 3'b101
`define TAP4 4'b1001
`define TAP5 5'b10010
`define TAP6 6'b100001
`define TAP7 7'b1000001
`define TAP8 8'b10001110
`define TAP9 9'b100001000
`define TAP10 10'b1000000100
`define TAP11 11'b10000000010
`define TAP12 12'b100000101001
`define TAP13 13'b1000000001101
`define TAP14 14'b10000000010101
`define TAP15 15'b100000000000001
`define TAP16 16'b1000000000010110
`define TAP17 17'b10000000000000100
`define TAP18 18'b100000000001000000
`define TAP19 19'b1000000000000010011
`define TAP20 20'b10000000000000000100
`define TAP21 21'b100000000000000000010
`define TAP22 22'b1000000000000000000001
`define TAP23 23'b10000000000000000010000
`define TAP24 24'b100000000000000000001101
`define TAP25 25'b1000000000000000000000100
`define TAP26 26'b10000000000000000000100011
`define TAP27 27'b100000000000000000000010011
`define TAP28 28'b1000000000000000000000000100
`define TAP29 29'b10000000000000000000000000010
`define TAP30 30'b100000000000000000000000101001
`define TAP31 31'b1000000000000000000000000000100
`define TAP32 32'b10000000000000000000000001100010
`define BITS 8 // Number of bits in the LFSR
`define TAPS `TAP8 // This must be the taps for the
// number of bits specified above
`define INIT 1 // This can be any non-zero value
// for initialization of the LFSR
// TOP MODULE
module random_number(
data);
// INPUTS
//input clk; // Clock
//input reset; // Reset
// OUTPUTS
output [`BITS-1:0] data; // LFSR data
// INOUTS
// SIGNAL DECLARATIONS
reg clk;
reg reset;
reg [`BITS-1:0] data;
// PARAMETERS
initial
begin
reset=0;
#4 reset=1;
#2 reset=0;
end
// ASSIGN STATEMENTS
initial
clk=0;
always
clk= #1 ~clk;
// MAIN CODE
// Look at the rising edge of clock or reset
always @(posedge clk or posedge reset) begin
if (reset)
data <= #`DEL `INIT;
else begin
// Shift all of the bits left
data[`BITS-1:1] <= #`DEL data[`BITS-2:0];
`ifdef ADD_ZERO // Use this code if data == 0 is required
// Create the new bit 0
data[0] <= #`DEL ^(data & `TAPS) ^ ~|data[`BITS-2:0];
`else // Use this code for a standard LFSR
data[0] <= #`DEL ^(data & `TAPS);
`endif
end
end
initial
#1000 $finish;
endmodule // LFSR
