一、综合词汇 1、印制电路:printed circuit 2、印制线路:printed wiring 3、印制板:printed board 4、印制板电路:printed circuit board (PCB) 5、印制线路板:printed wiring board(PWB) 6、印制元件:printed component 7、印制接点:printed contact 8、印制板装配:printed board assembly 9、板:board 10、单面印制板:single-sided printed board(SSB) 11、双面印制板:double-sided printed board(DSB) 12、多层印制板:mulitlayer printed board(MLB) 13、多层印制电路板:mulitlayer printed circuit board 14、多层印制线路板:mulitlayer prited wiring board 15、刚性印制板:rigid printed board 16、刚性单面印制板:rigid single-sided printed borad 17、刚性双面印制板:rigid double-sided printed borad 18、刚性多层印制板:rigid multilayer printed board 19、挠性多层印制板:flexible multilayer printed board 20、挠性印制板:flexible printed board 21、挠性单面印制板:flexible single-sided printed board 22、挠性双面印制板:flexible double-sided printed board 23、挠性印制电路:flexible printed circuit (FPC) 24、挠性印制线路:flexible printed wiring 25、刚性印制板:flex-rigid printed board, rigid-flex printed board 26、刚性双面印制板:flex-rigid double-sided printed board, rigid-flex double-sided printed 27、刚性多层印制板:flex-rigid multilayer printed board, rigid-flex multilayer printed board 28、齐平印制板:flush printed board 29、金属芯印制板:metal core printed board 30、金属基印制板:metal base printed board 31、多重布线印制板:mulit-wiring printed board 32、陶瓷印制板:ceramic substrate printed board 33、导电胶印制板:electroconductive paste printed board 34、模塑电路板:molded circuit board 35、模压印制板:stamped printed wiring board 36、顺序层压多层印制板:sequentially-laminated mulitlayer 37、散线印制板:discrete wiring board 38、微线印制板:micro wire board 39、积层印制板:buile-up printed board 40、积层多层印制板:build-up mulitlayer printed board (BUM) 41、积层挠印制板:build-up flexible printed board 42、表面层合电路板:surface laminar circuit (SLC) 43、埋入凸块连印制板:B2it printed board 44、多层膜基板:multi-layered film substrate(MFS) 45、层间全内导通多层印制板:ALIVH multilayer printed board 46、载芯片板:chip on board (COB) 47、埋电阻板:buried resistance board 48、母板:mother board 49、子板:daughter board 50、背板:backplane 51、裸板:bare board 52、键盘板夹心板:copper-invar-copper board 53、动态挠性板:dynamic flex board 54、静态挠性板:static flex board 55、可断拼板:break-away planel 56、电缆:cable 57、挠性扁平电缆:flexible flat cable (FFC) 58、薄膜开关:membrane switch 59、混合电路:hybrid circuit 60、厚膜:thick film 61、厚膜电路:thick film circuit 62、薄膜:thin film 63、薄膜混合电路:thin film hybrid circuit 64、互连:interconnection 65、导线:conductor trace line 66、齐平导线:flush conductor 67、传输线:transmission line 68、跨交:crossover 69、板边插头:edge-board contact 70、增强板:stiffener 71、基底:substrate 72、基板面:real estate 73、导线面:conductor side 74、元件面:component side 75、焊接面:solder side 76、印制:printing 77、网格:grid 78、图形:pattern 79、导电图形:conductive pattern 80、非导电图形:non-conductive pattern 81、字符:legend 82、标志:mark 二、基材:
1、基材:base material 2、层压板:laminate 3、覆金属箔基材:metal-clad bade material 4、覆铜箔层压板:copper-clad laminate (CCL) 5、单面覆铜箔层压板:single-sided copper-clad laminate 6、双面覆铜箔层压板:double-sided copper-clad laminate 7、复合层压板:composite laminate 8、薄层压板:thin laminate 9、金属芯覆铜箔层压板:metal core copper-clad laminate 10、金属基覆铜层压板:metal base copper-clad laminate 11、挠性覆铜箔绝缘薄膜:flexible copper-clad dielectric film 12、基体材料:basis material 13、预浸材料:prepreg 14、粘结片:bonding sheet 15、预浸粘结片:preimpregnated bonding sheer 16、环氧玻璃基板:epoxy glass substrate 17、加成法用层压板:laminate for additive process 18、预制内层覆箔板:mass lamination panel 19、内层芯板:core material 20、催化板材:catalyzed board ,coated catalyzed laminate 21、涂胶催化层压板:adhesive-coated catalyzed laminate 22、涂胶无催层压板:adhesive-coated uncatalyzed laminate 23、粘结层:bonding layer 24、粘结膜:film adhesive 25、涂胶粘剂绝缘薄膜:adhesive coated dielectric film 26、无支撑胶粘剂膜:unsupported adhesive film 27、覆盖层:cover layer (cover lay) 28、增强板材:stiffener material 29、铜箔面:copper-clad surface 30、去铜箔面:foil removal surface 31、层压板面:unclad laminate surface 32、基膜面:base film surface 33、胶粘剂面:adhesive faec 34、原始光洁面:plate finish 35、粗面:matt finish 36、纵向:length wise direction 37、模向:cross wise direction 38、剪切板:cut to size panel 39、酚醛纸质覆铜箔板:phenolic cellulose paper copper-clad laminates(phenolic/paper CCL) 40、环氧纸质覆铜箔板:epoxide cellulose paper copper-clad laminates (epoxy/paper CCL) 41、环氧玻璃布基覆铜箔板:epoxide woven glass fabric copper-clad laminates 42、环氧玻璃布纸复合覆铜箔板:epoxide cellulose paper core, glass cloth surfaces copper-clad laminates 43、环氧玻璃布玻璃纤维复合覆铜箔板:epoxide non woven/woven glass reinforced copper-clad laminates 44、聚酯玻璃布覆铜箔板:ployester woven glass fabric copper-clad laminates 45、聚酰亚胺玻璃布覆铜箔板:polyimide woven glass fabric copper-clad laminates 46、双马来酰亚胺三嗪环氧玻璃布覆铜箔板:bismaleimide/triazine/epoxide woven glass fabric copper-clad lamimates 47、环氧合成纤维布覆铜箔板:epoxide synthetic fiber fabric copper-clad laminates 48、聚四乙烯玻璃纤维覆铜箔板:teflon/fiber glass copper-clad laminates 49、超薄型层压板:ultra thin laminate 50、陶瓷基覆铜箔板:ceramics base copper-clad laminates 51、紫外线阻挡型覆铜箔板:UV blocking copper-clad laminates 三、基材的材料 1、 A阶树脂:A-stage resin 2、 B阶树脂:B-stage resin 3、 C阶树脂:C-stage resin 4、环氧树脂:epoxy resin 5、酚醛树脂:phenolic resin 6、聚酯树脂:polyester resin 7、聚酰亚胺树脂:polyimide resin 8、双马来酰亚胺三嗪树脂:bismaleimide-triazine resin 9、丙烯酸树脂:acrylic resin 10、三聚氰胺甲醛树脂:melamine formaldehyde resin 11、多官能环氧树脂:polyfunctional epoxy resin 12、溴化环氧树脂:brominated epoxy resin 13、环氧酚醛:epoxy novolac 14、氟树脂:fluroresin 15、硅树脂:silicone resin 16、硅烷:silane 17、聚合物:polymer 18、无定形聚合物:amorphous polymer 19、结晶现象:crystalline polamer 20、双晶现象:dimorphism 21、共聚物:copolymer 22、合成树脂:synthetic 23、热固性树脂:thermosetting resin 24、热塑性树脂:thermoplastic resin 25、感光性树脂:photosensitive resin 26、环氧当量:weight per epoxy equivalent (WPE) 27、环氧值:epoxy value 28、双氰胺:dicyandiamide 29、粘结剂:binder 30、胶粘剂:adesive 31、固化剂:curing agent 32、阻燃剂:flame retardant 33、遮光剂:opaquer 34、增塑剂:plasticizers 35、不饱和聚酯:unsatuiated polyester 36、聚酯薄膜:polyester 37、聚酰亚胺薄膜:polyimide film (PI) 38、聚四氟乙烯:polytetrafluoetylene (PTFE) 39、聚全氟乙烯丙烯薄膜:perfluorinated ethylene-propylene copolymer film (FEP) 40、增强材料:reinforcing material 41、玻璃纤维:glass fiber 42、 E玻璃纤维:E-glass fibre 43、 D玻璃纤维:D-glass fibre 44、 S玻璃纤维:S-glass fibre 45、玻璃布:glass fabric 46、非织布:non-woven fabric 47、玻璃纤维垫:glass mats 48、纱线:yarn 49、单丝:filament 50、绞股:strand 51、纬纱:weft yarn 52、经纱:warp yarn 53、但尼尔:denier 54、经向:warp-wise 55、纬向:weft-wise, filling-wise 56、织物经纬密度:thread count 57、织物组织:weave structure 58、平纹组织:plain structure 59、坏布:grey fabric 60、稀松织物:woven scrim 61、弓纬:bow of weave 62、断经:end missing 63、缺纬:mis-picks 64、纬斜:bias 65、折痕:crease 66、云织:waviness 67、鱼眼:fish eye 68、毛圈长:feather length 69、厚薄段:mark 70、裂缝:split 71、捻度:twist of yarn 72、浸润剂含量:size content 73、浸润剂残留量:size residue 74、处理剂含量:finish level 75、浸润剂:size 76、偶联剂:couplint agent 77、处理织物:finished fabric 78、聚酰胺纤维:polyarmide fiber 79、聚酯纤维非织布:non-woven polyester fabric 80、浸渍绝缘纵纸:impregnating insulation paper 81、聚芳酰胺纤维纸:aromatic polyamide paper 82、断裂长:breaking length 83、吸水高度:height of capillary rise 84、湿强度保留率:wet strength retention 85、白度:whitenness 86、陶瓷:ceramics 87、导电箔:conductive foil 88、铜箔:copper foil 89、电解铜箔:electrodeposited copper foil (ED copper foil) 90、压延铜箔:rolled copper foil 91、退火铜箔:annealed copper foil 92、压延退火铜箔:rolled annealed copper foil (RA copper foil) 93、薄铜箔:thin copper foil 94、涂胶铜箔:adhesive coated foil 95、涂胶脂铜箔:resin coated copper foil (RCC) 96、复合金属箔:composite metallic material 97、载体箔:carrier foil 98、殷瓦:invar 99、箔(剖面)轮廓:foil profile 100、光面:shiny side 101、粗糙面:matte side 102、处理面:treated side 103、防锈处理:stain proofing 104、双面处理铜箔:double treated foil 四、设计 1、原理图:shematic diagram 2、逻辑图:logic diagram 3、印制线路布设:printed wire layout 4、布设总图:master drawing 5、可制造性设计:design-for-manufacturability 6、计算机辅助设计:computer-aided design.(CAD) 7、计算机辅助制造:computer-aided manufacturing.(CAM) 8、计算机集成制造:computer integrat manufacturing.(CIM) 9、计算机辅助工程:computer-aided engineering.(CAE) 10、计算机辅助测试:computer-aided test.(CAT) 11、电子设计自动化:electric design automation .(EDA) 12、工程设计自动化:engineering design automaton .(EDA2) 13、组装设计自动化:assembly aided architectural design. (AAAD) 14、计算机辅助制图:computer aided drawing 15、计算机控制显示:computer controlled display .(CCD) 16、布局:placement 17、布线:routing 18、布图设计:layout 19、重布:rerouting 20、模拟:simulation 21、逻辑模拟:logic simulation 22、电路模拟:circit simulation 23、时序模拟:timing simulation 24、模块化:modularization 25、布线完成率:layout effeciency 26、机器描述格式:machine descriptionm format .(MDF) 27、机器描述格式数据库:MDF databse 28、设计数据库:design database 29、设计原点:design origin 30、优化(设计):optimization (design) 31、供设计优化坐标轴:predominant axis 32、表格原点:table origin 33、镜像:mirroring 34、驱动文件:drive file 35、中间文件:intermediate file 36、制造文件:manufacturing documentation 37、队列支撑数据库:queue support database 38、元件安置:component positioning 39、图形显示:graphics dispaly 40、比例因子:scaling factor 41、扫描填充:scan filling 42、矩形填充:rectangle filling 43、填充域:region filling 44、实体设计:physical design 45、逻辑设计:logic design 46、逻辑电路:logic circuit 47、层次设计:hierarchical design 48、自顶向下设计:top-down design 49、自底向上设计:bottom-up design 50、线网:net 51、数字化:digitzing 52、设计规则检查:design rule checking 53、走(布)线器:router (CAD) 54、网络表:net List 55、计算机辅助电路分析:computer-aided circuit analysis 56、子线网:subnet 57、目标函数:objective function 58、设计后处理:post design processing (PDP) 59、交互式制图设计:interactive drawing design 60、费用矩阵:cost metrix 61、工程图:engineering drawing 62、方块框图:block diagram 63、迷宫:moze 64、元件密度:component density 65、巡回售货员问题:traveling salesman problem 66、自由度:degrees freedom 67、入度:out going degree 68、出度:incoming degree 69、曼哈顿距离:manhatton distance 70、欧几里德距离:euclidean distance 71、网络:network 72、阵列:array 73、段:segment 74、逻辑:logic 75、逻辑设计自动化:logic design automation 76、分线:separated time 77、分层:separated layer 78、定顺序:definite sequence 五、形状与尺寸: 1、导线(通道):conduction (track) 2、导线(体)宽度:conductor width 3、导线距离:conductor spacing 4、导线层:conductor layer 5、导线宽度/间距:conductor line/space 6、第一导线层:conductor layer No.1 7、圆形盘:round pad 8、方形盘:square pad 9、菱形盘:diamond pad 10、长方形焊盘:oblong pad 11、子弹形盘:bullet pad 12、泪滴盘:teardrop pad 13、雪人盘:snowman pad 14、 V形盘:V-shaped pad 15、环形盘:annular pad 16、非圆形盘:non-circular pad 17、隔离盘:isolation pad 18、非功能连接盘:monfunctional pad 19、偏置连接盘:offset land 20、腹(背)裸盘:back-bard land 21、盘址:anchoring spaur 22、连接盘图形:land pattern 23、连接盘网格阵列:land grid array 24、孔环:annular ring 25、元件孔:component hole 26、安装孔:mounting hole 27、支撑孔:supported hole 28、非支撑孔:unsupported hole 29、导通孔:via 30、镀通孔:plated through hole (PTH) 31、余隙孔:access hole 32、盲孔:blind via (hole) 33、埋孔:buried via hole 34、埋/盲孔:buried /blind via 35、任意层内部导通孔:any layer inner via hole (ALIVH) 36、全部钻孔:all drilled hole 37、定位孔:toaling hole 38、无连接盘孔:landless hole 39、中间孔:interstitial hole 40、无连接盘导通孔:landless via hole 41、引导孔:pilot hole 42、端接全隙孔:terminal clearomee hole 43、准表面间镀覆孔:quasi-interfacing plated-through hole 44、准尺寸孔:dimensioned hole 45、在连接盘中导通孔:via-in-pad 46、孔位:hole location 47、孔密度:hole density 48、孔图:hole pattern 49、钻孔图:drill drawing 50、装配图:assembly drawing 51、印制板组装图:printed board assembly drawing 52、参考基准:datum referance 54、基准尺寸:reference dimension 55、参考尺寸:reaerence dimension 56、直接量定尺寸:direct dimensioning 57、基准图:datum feature 58、基准边:reference edge 59、导线设计距离:design space of conductor 60、导线设计宽度:design width of conductor 61、中心距:center to center spacing 62、线宽/间距:conductor width/space 63、节距:pitch 64、精细节距:fine pitch 65、层:layer 66、层间距:layer-to-layer spacing 67、边距:edge spacing 68、外形线:trim line 69、截面积:crossection area 70、真实值表测量:truth table test 71、准确位置:true position tolerance 72、精确位置:accuracy 73、精确位置误差:cumulative tolerance 74、精确度:accuracy 75、累积误差:cumulative tolerance 76、焊垫:footprint 77、外层:external layer 78、内层:internal layer 79、接地层:ground plane 80、接地层隔离:ground plane clearance 81、电压层:voltage plane 82、电源层隔离:voltage plane clearance 83、电源层:power plane, bus plane 84、导通网络:basic grid 85、导通网格:track grid 86、导通孔网格:via grid 87、连通盘网格:pad (land) grid 88、定位偏差:positional tolerance 89、对准靶标:bornb sight 90、梳状图形:comb pattern 91、对准标记:register mark 92、散热层:heat sink plane 六、电气互连 1、表面间连接:interlayer connection 2、层间连接:interlayer connection 3、内层连接:innerlayer connection 4、非功能表面连接:nonfunctional interfacial connection 5、跨接线:jumper wire 6、节(交)点:node 7、附加线:haywire 8、端接(点):terminal 9、连接线:terminated line 10、端接:termination 11、连接端:pad, land 12、贯穿连接:through connection 13、支线:stub 14、印制插头:tab 15、键槽:keying slot 16、连接器:connector 17、板边连接器:edge board connector 18、连接器区:connector area 19、直角板边连接器:right angle edge connector 20、偏槽口:polarizing slot 21、偏置端接区:offset terminal area 22、接地:ground 23、端接隔离(空环):terminal clearance 24、连通性:continuity 25、连接器接触:connector contact 26、接触面积:contact area 27、接触间距:contact spacing 28、接触电阻:contact resistance 29、接触尺寸:contact size 30、元件引腿(脚):component lead 31、元件插针:component pin 32、最小电气间距:minimum electrical spacing 33、导电性:conductivity 34、边卡连接器:card-edge connector 35、插卡连接器:card-insertion connector 36、载流量:current-carrying capacity 37、蹯径:path 38、最短路径:shortest path 39、关键路径:critical path 40、倒角:miter 41、串推:daisy chain 42、斯坦纳树:steiner tree 43、最小生成树:minimum spanning tree (MST) 44、瓶颈宽度:necked width 45、短叉长度:spur length 46、短柱长度:stub length 47、曼哈顿路径:manhattan path 48、连接度(性):connectivity 七、其它 1、主面:primary side 2、辅面:secondary side 3、支撑面:supporting plane 4、信号:signal 5、信号导线:signal conductor 6、信号地线:signal ground 7、信号速率:signal rate 8、信号标准化:signal standardization 9、信号层:signal layer 10、寄生信号:spurious signal 11、串扰:crosstalk 12、电容:capacitance 13、电容耦合:capacitive coupling 14、电磁干扰:electromagnetic interference 15、电磁屏蔽:electromangetic shielding 16、噪音:noise 17、电磁兼容性:electromagnetic compatbility 18、特性阻抗:impedance 19、阻抗匹配:impedance match 20、电感:inductance 21、延迟:delay 22、微带线:microstrip 23、带状线:stripline 24、探测点:probe point 25、开窗口:cross hatching 26、跨距:span 27、共面性(度):coplanarity 28、埋入电阻:buried resistance 29、黄金板:golden board 30、芯板:core board 31、薄基芯:thin core 32、非均衡传输线:unbalanced transmission line 33、阀值:threshold 34、极限值:threshold limit value(TLV) 35、散热层:heat sink plane 36、热隔离:heat sink plane 37、导通孔堵塞:via filiing 38、波动:surge 39、卡板:card 40、卡板盒/卡板柜:card cages/card racks 41、薄型多层板:thin type multilayer board 42、埋/盲孔多层板: 43、模块:module 44、单芯片模块:single chip module (SCM) 45、多芯片模块:multichip module (MCM) 46、多芯片模块层压基板:laminate substrate version of multichip module (MCM-L) 47、多芯片模块陶瓷基数板:ceramic substrate version o fmultichip module (MCM-C) 48、多芯片模块薄膜基板:deposition thin film substrate version of multilayer module (MCM-D) 49、嵌入凸块互连技术:buried bump interconnection technology (B2 it) 50、自动测试技术:automatic test equipment (ATE) 51、芯板导通孔堵塞:core board viafilling 52、对准标记:alignment mark 53、基准标记:fiducial mark 54、拐角标记:corner mark 55、剪切标记:crop mark 56、铣切标记:routing mark 57、对位标记:registration mark 58、缩减标记:reduvtion mark 59、层间重合度:layer to layer registration 60、狗骨结构:dog hone 61、热设计:thermal design 62、热阻:thermal resistance |
