Group Delay and Phase Delay in Filters
Summary. In this chapter, we explore the way in which a filter’s output is delayed
with respect to its input. We show that if the filter’s phase is not linear, then the
filter delays signals with different carrier frequencies by different amounts.
Keywords. group delay, phase delay, bandpass signals, carrier frequency.
27.1 Group and Phase Delay in Continuous-time Filters
Suppose that one has a narrow-band bandpass signal, y(t). That is, suppose
that y(t) can be written as
y(t) = e2πjFctx(t)
where X(f) = 0 for all |f| > B, B << Fc , and Fc is the signal’s carrier
frequency.
Consider the Fourier transform. representation of x(t)
x(t) = _ B
−B
e2πjftX(f) df
= _ B
−B
|X(f)|ej_ X(f)e2πjft df.
We find that x(t) is composed of sinusoids of the form
|X(f)|ej_ X(f)e2πjft, |f| ≤ B.
Similarly, we find that y(t) is composed of sinusoids of the form
|X(f)|ej_ X(f)e2πj(f+Fc)t, |f| ≤ B.
186 27 Group Delay and Phase Delay in Filters
When the components of the function y(t) pass through a filter whose frequency
response is H(f), then the components of the resulting function, which
we call z(t), are
|H(Fc + f)|ej_ H(Fc+f)|X(f)|ej_ X(f)e2πj(f+Fc)t, |f| ≤ B.
Let us define the function ΘH(f) ≡ _ H(f). For relatively small f we can
approximate ΘH(Fc + f) by ΘH(Fc) + Θ_
H(Fc)f. Also, assuming that the
magnitude of the filter response does not change much for small f, we can
approximate |H(Fc +f)| by |H(Fc)|. (This “0th-order” approximation is reasonable,
because a small enough error in the magnitude can only produce a
small error in the final estimate of the signal.)We approximate the constituent
components of z(t) by
|H(Fc)|ej(ΘH(Fc)+Θ
_
H(Fc)f)|X(f)|ej_ X(f)e2πj(f+Fc)t, |f| ≤ B.
Rewriting this, we find that the constituent components of z(t) are
|H(Fc)|ejΘH(Fc)e2πjFct|X(f)|ej_ X(f)ejΘ
_
H(Fc)f e2πjft, |f| ≤ B.
This, in turn, can be written as
|H(Fc)|e2πjFc(t+ΘH(Fc)/(2πFc))|X(f)|ej_ X(f)e2πjf
