Understanding Loop based and Device Based Algorithms
Two algorithms--the loop based and the device based, are available for small-signal
stability analysis. Both algorithms are based on the calculation of Bodes return ratio.
Loop gain waveform, gain margin, and phase margin are the analysis output.
The probe parameter must be specified to perform. stability analysis. When it points to a
current probe or voltage source instance, the loop based algorithm will be invoked; when
it points to a supported active device instance, the device based algorithm will be
invoked.
Loop Based Algorithm
The loop based algorithm calculates the true loop gain that consists of normal loop gain
and reverse loop gain. The loop based algorithm requires the probe being placed on the
feedback loop to identify and characterize the particular loop of interest. The
introduction of the probe component should not change any of the circuit
characteristics.
The loop based algorithm provides accurate stability information for single loop circuits,
and multiloop circuits in which a probe component can be placed on a critical wire to break
all loops. For a general multiloop circuit, such a critical wire may not be available. The
loop based algorithm can only be performed on individual feedback loops to ensure they
are stable. Although the stability of all feedback loops is only a necessary condition for
the whole circuit to be stable, the multiloop circuit tends to be stable if all individual
loops are associated with reasonable stability margins.
The device based algorithm calculates the loop gain around a particular active device.
This algorithm is often applied to assess the stability of circuit design in which local
feedback loops cannot be neglected; the loop based algorithm cannot be performed for
these applications since the local feedback loops are inside the devices, they are not
accessible from the schematic level or netlist level to insert the probe component.
With the probe parameter points to a particular active device, the dominant controlled
source in the device will be nulled during the analysis. The dominant controlled source
is defined as by nulling this source renders the active device to be passive. The device
based algorithm produces accurate stability information for a circuit in which a critical
active device can be identified such that nulling the dominant gain source of this device
renders the whole network to be passive.
