Well, because this blog is a technical blog, I thought it was a good time for a geek-friendly post . Armed with my usual optimism and with the help of our in-house expert Dave Cronauer, I decided to give you a few tips to make your Verilog-AMS module more efficient. Dealing with customer issues for many years, one recurrent observation I had about behavioral models is that performance is strongly correlated with the quality of your module. Using a simpler model and changing some of your modeling techniques can bring you a significant speed up in term of simulations.
So I wanted to provide a few hints on how to improve performance significantly by slightly tweaking your Verilog-A model. As usual, feel free to add to this post with any comments you may have.
1- Add transition() filters
When moving from the discrete domain to the continuous domain, use a transition filter. The filter smooths the discrete event and provides a continuous path for the analog solver. For example, change this 1 bit d2a from this:
module d2a1bit1 (d,a);
input d;
logic d;
inout a;
electrical a;
analog begin
V(a) <+ ((d)? 0.0 : 2.5);
end
endmodule
to:
module d2a1bit2 (d,a);
input d;
logic d;
inout a;
electrical a;
analog begin
V(a) <+ transition(((d)? 0.0 : 2.5),0,20p);
end
endmodule
2- Use branch statements
This makes them more readable and less prone to typos by replacing long strings with shorter variables. As well, it insures continuity when querying voltages and currents. Redo a capacitor model from this:
module cap1 (p,m);
inout p,m;
electrical p,m;
analog begin
I(p,m) <+ ddt(1p*V(p,m));
end
endmodule
to this:
module cap2 (p,m);
inout p,m;
electrical p,m;
branch (p,m) b1;
analog begin
I(b1) <+ ddt(1p*V(b1));
end
endmodule
3- Model in terms of current
When possible, create models in the form. of “I(port) <+ function(other variables);”. Most analog simulators create their matrix by summing currents at nodes, using KCL. Redo a resistor model from this:
module res1 (p,m);
inout p,m;
electrical p,m;
branch (p,m) b1;
analog begin
V(b1) <+ 500*I(b1);
end
endmodule
to this better model:
module res2 (p,m);
inout p,m;
electrical p,m;
branch (p,m) b1;
analog begin
I(b1) <+ V(b1)/500;
end
endmodule
An even better model replaces the division with multiplication:
module res3 (p,m);
inout p,m;
electrical p,m;
branch (p,m) b1;
analog begin
I(b1) <+ V(b1)*0.002;
end
endmodule
4-Make a better switch model
A very simple relay model is shown in the Verilog-AMS LRM of the analog section is shown below:
analog begin
closed = (V(ps,ns) > vth ? 1 : 0);
if (closed)
V(p,n) <+ 0;
else
I(p,n) <+ 0;
end
This is a poor model as the resistance across the switch changes instantly from 0.0 (ideal short) to infinite (ideal open). A better model has finite conductance
analog begin
if (closed) cond = 1.0;
else cond = 1.0e-9;
I(b1) <+ V(b1)*transition(cond,0,10p);
end
endmodule
In small test benches, both circuits may simulate. But in larger circuits with capacitance and inductance on the nets, the first model may have convergence problems. The second model will simulate better.
5-Reduce the analog section
Move as much code as possible from the analog section, contained within “analog begin” to “end” statements, to digital sections. Typically, the analog section is more computationally intensive, so you want to make this as compact as possible. Also, segmenting the large analog block into smaller digital and analog blocks makes the model more readable. For example, the power checking and the digital logic section of a module should be taken out of the analog section and kept as a self-contained digital sections
analog begin
@(above(V(sup),0.5)) begin
// Supply active code
end
@(digital_in) begin
// Digital logic
end
// Remaining analog code
end
endmodule
should be
always @(digital_in) begin
// Digital logic
end
always @(above(V(sup),0.5)) begin
end
analog begin
end
endmodule
6-Use above() instead of cross()
The cross() function does not fire during DC operating point, only during transient analysis. This may cause the model not to be in the proper state for simulation. The above() function works for both DC and transient analyses, so this function should be used instead.
And last but not least ,
7-Make models as simple as possible
I know you would have come up with this by yourself, but that applies to any modeling language.
from Hélène Thibiéroz 's bolg: http://blogs.synopsys.com/analoginsights/2012/07/19/7-tips-to-improve-your-verilog-ams-model/
