Is there a test bench showing how to add jitter to the PRBS source?
Answer:
The attached example contains a sample and hold Verilog-A model which can be used to add jitter to a PRBS source. Care should be taken so that the jitter clock occurs in middle of PRBS clock rate to avoid sampling on the rising or falling edge.
---------------------------Testbech : jitter.sp ---------------------------
* jitter
.option post
.hdl "sample_hold.va"
.param rate = 1066e6
.param delay = 1ns
.param slew = 50p
v0 n0 0 pulse (0 1.5 "delay-slew+(1/rate-slew)/2" slew slew "1/rate-slew" "2/rate")
r0 n0 0 1k
vj jitter 0 pulse (0 1.5 "delay-slew+(1/rate-slew)/2" slew slew "1/rate-slew" "2/rate")
+perjitter=50p
rj jitter 0 1k
vp prbs 0 LFSR 0 1.5 delay slew slew rate 1 [5 2]
rp prbs 0 1k
x0 prbs out jitter sample_hold threshold=0.75 risetime='slew'
.tran 1p 100n
.probe v(*)
.end
---------------------------Verilog-A : sample_hold.va ---------------------------
// Sample and hold circuit based on LRM 2.0 example p 6.14
`include "disciplines.vams"
module sample_hold(in,out,clk);
input in,clk;
output out;
voltage in,out,clk;
parameter real risetime = 1.0e9 from (0:inf);
parameter real threshold = 2.5;
real v;
analog begin
@(cross(V(clk)-threshold,0))
v = V(in);
V(out) <+ transition(v,0,risetime);
end
endmodule
Run command:
% hspice -i jitter.sp -o jitter
How can I generate a pulse waveform. (source) with period and frequency jitter that I can use during the functional verification of designs like PLLs and SERDES?
Answer:
This can be done effectively and efficiently with the Verilog-A code shown below. ////////////////////////////////////////////////////////////// `include "disciplines.vams" `include "constants.vams" module osc (out); output out; electrical out; parameter real freq=20e6 from (0:inf); //output frequency parameter real Vlo=0, Vhi=1; //output level parameter real tt=0.01/freq from (0:inf); //rise time and fall time parameter real fmJitter=0 from [0:0.1/freq); parameter real pmJitter=0 from [0:0.1/freq); integer n, fmSeed, pmSeed; real next, dT, dt; analog begin @(initial_step) begin fmSeed = 286; pmSeed = -459; next = 0.5/freq + $realtime; end @(timer(next + dt)) begin n = !n; dT = fmJitter*$dist_normal(fmSeed,0,1); dt = pmJitter*$dist_normal(pmSeed,0,1); next = next + 0.5/freq + 0.707*dT; end V(out) <+ transition(n ? Vhi : Vlo, 0, tt); end // endmodule ////////////////////////////////////////////// The jitter can have any of the following distributions: Distribution verilog A functions ************************************************************** Uniform. Distribution $dist_uniform. Normal (Gaussian) Distribution $dist_normal Exponential Distribution $dist_exponential Poisson Distribution $dist_poisson Chi-Square Distribution $dist_chi_square Erlang Distribution $dist_erlang **************************************************************** For more information please refer to the Verilog-A LRM.+++++++++++++++++++++++++++++++++++++++++++++++++++++++++
