Does HSPICE support encryption of Verilog-A modules?
Answer:
Beginning with the E-2010.12-SP2 release, HSPICE can encrypt Verilog-A modules. The two methods supported are: 1) 8-Byte encryption 2) 3DES encryption (private or randkey)————————————————————————————————
Since HSPICE no longer creates a *.cml (compiled Verilog-A) file, how can we share the Verilog-A module and at the same time protect its contents?
Answer:
Verilog-A files can be encrypted using the Metaencrypt utility and then the ecrypted file can be called in the netlist using the .hdl command.
For example:
To encrypt the Verilog-A file, opamp.va, use the command:
% metaencrypt -i opamp.va -o opamp_spi.inc -t randkey
The encypted file opamp_spi.inc will be generated. This file can be included in the netlist using the .HDL command.
**opamp.sp .HDL opamp_spi.inc
Using this method, the contents of the Verilog-A model can be protected and shipped to customers.
For more information, see the Using Verilog-A chapter in the HSPICE
User Guide: Advanced Analog Simulation and Analysis and the Library and
Data Encryption chapter in the HSPICE User Guide: Basic Simulation and
Analysis.
