You need to raise the PDF version of the document itself. Locate the file dvipdfmx.cfg
, the configuration file of the driver program XeTeX uses, and edit the V
line to be
V 6
Don't forget to put the default settings back afterwards — they are there for a reason! Instead of modifying the original file you can also make a copy in your local TEXMF tree.
