热度 1| |
1. editor = "TEXT_EDITOR_NAME"
Where TEXT_EDITOR_NAME is an editor such as nedit, gedit, vim, ect.
2. ddsNewsClose()
Close the "What's new" window
3. hiSetUndoLimit(10)
Set the undo limit to 10
4. hiResizeWindow(window(1) list(1:25 800:200))
Resize the Command Interface Window (CIW). The CIW is the command line window. The window size and position is set by defining the pixel positions of the bottom-left (BL) and top-right (TR) location of the window. The bottom-left corner of the screen is the origin. The syntax is
list([BL_horizontal_position]:[BL_vertical_position] [TR_horizontal_position]:[TR_vertical_position])
list(1:25 800:200) sets it up in the bottom left part of the screen.
5. ddsOpenLibManager()
Open the library manager window. You can also add this command in your leBindKeys.il file to do the same thing.
6. asiSetEnvOptionVal( asiGetTool('spectre) 'modelFiles '(("/model_file_path" "")) )
Add a model files path
Reference:
https://secure.engr.oregonstate.edu/wiki/ams/index.php/Cadence/TipsAndTricks
