I. OverView
II. Using SKILL Commands
There are numerous ways to execute SKILL commands and programs.
SKILL commands can be entered into and evaluated on the command line
of the Command Interpreter Window.You can enter valid SKILL syntax into the CIW. For example, on the
command line enter:
2 + 2
4 ... SKILL response
III. OCEAN
Open Command Environment for ANalysis
■ OCEAN is a product included in the Virtuoso Analog Design Environment.
■ Use OCEAN for the following tasks:
❏ To create scripts to run batch mode simulations.
❏ To run parametric, Corners, Monte Carlo, and Optimization analyses.
❏ To run long simulations without starting the graphical user interface.
❏ To run simulations from a non-graphical, remote terminal.
■ OCEAN is based on the SKILL programming language.
Scripts are created automatically within the Virtuoso Analog Design
Environment. These scripts can be saved, modified, and used to run batch
simulations.
■ After the design has been debugged in the Virtuoso Analog Design
Environment, use OCEAN to test your circuit under a variety of conditions.
Run OCEAN from a UNIX prompt or from the CIW.
■ In UNIX:
Enter ocean from the UNIX prompt to start.
This loads awd.exe and loads and reads the .oceanrc startup file. The
.oceanrc file contains OCEAN commands that include alias definitions, and
user-defined procedures and characterization scripts.
An ocean> prompt appears in the UNIX window. Enter commands at the
prompt.
The .cdsinit file is not loaded.
Type exit to quit OCEAN.
■ In the CIW, through the Virtuoso Analog Design Environment:
❏ Enter OCEAN commands at any time.
❏ The .oceanrc is not loaded automatically. If it exists, load it by entering:
load “.oceanrc”
