Name Description Units Default
Pckappas Cross-term dependence of ckappas 0.0
Pckappad Cross-term dependence of ckappad 0.0
Pcf Cross-term dependence of cf 0.0
Pclc Cross-term dependence of clc 0.0
Pcle Cross-term dependence of cle 0.0
Palpha0 Cross-term dependence of alpha0 0.0
Palpha1 Cross-term dependence of alpha1 0.0
Pbeta0 Cross-term dependence of beta0 0.0
Pagidl Cross-term dependence of agidl 0.0
Pbgidl Cross-term dependence of bgidl 0.0
Pcgidl Cross-term dependence of cgidl 0.0
Pegidl Cross-term dependence of egidl 0.0
Paigc Cross-term dependence of aigc 0.0
Pbigc Cross-term dependence of bigc 0.0
Pcigc Cross-term dependence of cigc 0.0
Paigsd Cross-term dependence of aigsd 0.0
Pbigsd Cross-term dependence of bigsd 0.0
Pcigsd Cross-term dependence of cigsd 0.0
Paigbacc Cross-term dependence of aigbacc 0.0
Pbigbacc Cross-term dependence of bigbacc 0.0
Pcigbacc Cross-term dependence of cigbacc 0.0
Paigbinv Cross-term dependence of aigbinv 0.0
Pbigbinv Cross-term dependence of bigbinv 0.0
Pcigbinv Cross-term dependence of cigbinv 0.0
Pnigc Cross-term dependence of nigc 0.0
Pnigbinv Cross-term dependence of nigbinv 0.0
Pnigbacc Cross-term dependence of nigbacc 0.0
Pntox Cross-term dependence of ntox 0.0
Peigbinv Cross-term dependence for eigbinv 0.0
Ppigcd Cross-term dependence for pigcd 0.0
Ppoxedge Cross-term dependence for poxedge 0.0
Pvfbcv Cross-term dependence of vfbcv 0.0
Pvfb Cross-term dependence of vfb 0.0
Pacde Cross-term dependence of acde 0.0
Pmoin Cross-term dependence of moin 0.0
Pnoff Cross-term dependence of noff 0.0
Pvoffcv Cross-term dependence of voffcv 0.0
Pxrcrg1 Cross-term dependence of xrcrg1 0.0
Pxrcrg2 Cross-term dependence of xrcrg2 0.0
Plambda Cross-term dependence of Lambda 0.0
Pvtl Cross-term dependence of Vtl 0.0
Pxn Cross-term dependence of Xn 0.0
Peu Cross-term dependence of eu 0.0
Pvfbsdoff Cross-term dependence of Vfbsdoff 0.0
Saref Reference distance between OD edge to poly of one side m 1.0e-6
Sbref Reference distance between OD edge to poly of the other side m 1.0e-6
Wlod Width parameter for stress effect m 0.0
Ku0 Mobility degradation/enhancement coefficient for LOD m 0.0
Kvsat Saturation velocity degradation/enhancement parameter for LOD m 0.0
Kvth0 Threshold shift parameter for LOD V*m 0.0
Tku0 Temperature coefficient of Ku0 0.0
Llodku0 Length parameter for U0 LOD effect 0.0
Wlodku0 Width parameter for U0 LOD effect 0.0
Llodvth Length parameter for Vth LOD effect 0.0
Wlodvth Width parameter for Vth LOD effect 0.0
Lku0 Length dependence of Ku0 0.0
Wku0 Width dependence of Ku0 0.0
Pku0 Cross-term dependence of Ku0 0.0
Lkvth0 Length dependence of Kvth0 0.0
Wkvth0 Width dependence of Kvth0 0.0
Pkvth0 Cross-term dependence of Kvth0 0.0
Stk2 K2 shift factor related to stress effect on Vth m 0.0
Lodk2 K2 shift modification factor for stress effect 1.0
Steta0 Eta0 shift factor related to stress effect on Vth m 0.0
Lodeta0 Eta0 shift modification factor for stress effect 1.0
Noia Flicker noise parameter 6.25e41 (NMOS),
6.188e40 (PMOS)
Noib Flicker noise parameter 3.125e26 (NMOS),
1.5e25 (PMOS)
Noic Flicker noise parameter 8.75
Tnoia Thermal noise parameter 1.5
Tnoib Thermal noise parameter 3.5
Rnoia Thermal noise coefficient 0.577
Rnoib Thermal noise coefficient 0.37 (for version = 4.20, 4.21 or 4.30), 0.5164 (otherwise)
Ntnoi Thermal noise parameter 1.0
Em Flicker noise parameter V/m 4.1e7
Ef Flicker noise frequency exponent 1.0
Af Flicker noise exponent 1.0
Kf Flicker noise coefficient 0.0
wBvsub substrate junction reverse breakdown voltage warning V
wBvds gate oxide breakdown voltage warning V
wBvds drain-source breakdown voltage warning V
wIdsmax maximum drain-source current warning A
wPmax maximum power dissipation warning W
AllParams DataAccessComponent (DAC)-based parameters
Rgeomod S/D resistance and contact model selector 0
Nf Number of fingers 1.0
